Steering help-Upgrade? - Ford Powerstroke Diesel Forum
post #1 of 19 Old 07-04-2013, 09:11 AM Thread Starter
BioStroker's Avatar
Quoted: 4 Post(s)
Happy 4th everyone! Yesterday something happened with my steering. During slow speed turns (I notice it mostly in reverse) it's feeling like my power steering is going out and I really have to muscle the steering wheel around. The fluid level doesn't seem to have dropped, but I did notice little "squirt" marks from the PS fluid (ATF) along the way when parallel parking. I couldn't tell if the leak was from the power steering pump or the steering box. What does everyone think?
If I am going to be doing some steering work, I am interested in finding out if there is anything I can do to upgrade the steering system, because the steering on my truck has always been marginal at best. I have a lot of play in the steering wheel when cruising down the highway, and it would be nice if the whole system was tighter. Are there any somewhat affordable upgrades out there? Either stock or a new system recommendations would be great. I don't mind spending a little money if it's going to help. Recommendations with ballpark on parts would be great. I will probably have someone install it as well as I don't have the special tools, and there is nowhere to rent them where I live. Somebody mentioned to me that one of the shops around here has had good luck messing with the ball joints to improve the steering-any merit to that?
Oh, and I have a 2-4" lift on my truck (not exactly sure, it was on it when I bought it), and I'm running 285 75 16 tires, so nothing too huge there.
Anyway, thanks for the help and suggestions, and enjoy the independence of this great country!
2000 F350 Crew Cab Short Bed,
AIS Intake/Zoodad, 203 thermostat, Billet Housing
Vegistroke WVO conversion, AIH Delete, Wicked Wheel, TurboMaster Wastegate controller
Pyro/Boost/Tranny Guages
4" Magnaflow Straight Pipe
DP-Tuner F6 80hp Econo, 80hp Tow, Decel, 100hp Performance, 120hp Race
BioStroker is offline
post #2 of 19 Old 07-05-2013, 07:14 AM Thread Starter
BioStroker's Avatar
Quoted: 4 Post(s)
Bump...anyone?
post #3 of 19 Old 07-05-2013, 08:42 AM
Fall Guy's Avatar
Quoted: 7 Post(s)
I had the same feel as your describing on my 01.
Ended up changing the factory steering pump out & installing a Red Head steering box.
Red Head Steering Gears - Steering Gear | Steering Gear Box
This helped out. Good luck
Fall Guy is offline
post #4 of 19 Old 07-05-2013, 09:42 AM Thread Starter
BioStroker's Avatar
Quoted: 4 Post(s)
Thank you. Do you happen to remember how much it cost? Easy install? I'm guessing I just need to call them and tell them what application it's for? Did it make a pretty significant difference? Does it still use the factory power steering pump? Sorry for all the questions, I just don't know much about this stuff!
post #5 of 19 Old 07-05-2013, 10:07 AM
ZMANN's Avatar
Quoted: 1469 Post(s)
Red head is ok they do ship out some boxes that need to go right back
if you go Reman Ford is your best bet according to feedback from members
and My own experience with auto zone and 2 boxes before I went down their rebuilder and got My core back
if I need a gear rebuilt I am having it done locally at benchworks
We Miss you Ronnie
ZMANN is offline
post #6 of 19 Old 07-05-2013, 10:10 AM
ThomasvillePavers's Avatar
I have also heard good reviews about Red head steering gear and need to do the same, I have a reman pump from Napa that works great just need the steering gear now to eliminate the slop.
-Brad
00' F350 CC DRW still pushing well past 300K: 6637, GTP38R, 5.6k mod on turn dial, superchips, trans command, Torque pro on Galxy S2 for PID monitor, OD lock, 4" straight pipe, condensor cooler w/electric fan, watersprayed intercooler, 08' taillights, 05' headlights, BD valve body kit, all door locks foiled, full LED exterior light kit, and the list is still growing.
ThomasvillePavers is offline
post #7 of 19 Old 07-05-2013, 10:13 AM Thread Starter
BioStroker's Avatar
Quoted: 4 Post(s)
I just got off the phone with Redhead and it's looking like it's in the $350 ballpark for their steering boxes. Sounds like they just re-valve and tighten up the stock OEM boxes. They did ask me if it's a 8 or 9 spline. I got under the truck and tried to count them, which was kind of difficult considering I'm not a contortionist. I think it's a 9 spline for my 2000 F350. Sound right? Build date 01/00
post #8 of 19 Old 07-05-2013, 10:35 AM Thread Starter
BioStroker's Avatar
Quoted: 4 Post(s)
How can you tell if they rebuilt it properly?
post #9 of 19 Old 07-05-2013, 11:00 AM
ZMANN's Avatar
you install it have a problem call them they ship you a new one
sounds like fun huh LOL
rare but it's been posted a few times on here
My rebuild would walk the truck in one direction or the other without steering input
We Miss you Ronnie
ZMANN is offline
post #10 of 19 Old 07-05-2013, 11:38 AM Thread Starter
BioStroker's Avatar
Quoted: 4 Post(s)
Yeah, sounds like fun. Especially when sending your core back on top of it all.
Are the Ford Reman ones you mentioned only a Ford dealer thing, or a reman one from any auto parts store? Any difference?
I think it's my pump that's leaking anyway (I don't think the fluid even runs through the gear box, right?), but I figure if I'm replacing the pump I may as well try and tighten up the steering at the same time.
