Tire GONE! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-02-2013, 10:18 PM Thread Starter
Skorchrock's Avatar
Tire GONE!
RF 35" Toyo M/T on my 08 is getting chewed up on the outside and the truck pulls right. Took it to NTB and they said everything was good? The LF.......noooooo wear. Any ideas?
Skorchrock is offline
post #2 of 6 Old 07-03-2013, 04:05 PM
Sounds like an alignment or bearing issue. If everything was good, the tire wouldn't be chewed up and it wouldn't be pulling to the right.
Support your truck with jack stands under the axle and try the following:
Trying to move the tire with you hands at the 3 & 9 o'clock positions will check tie rod ends.
Put a board under the tire from the side of the truck and try to lift the tire, movement here will indicate a bad ball joint or unit bearing.
If the tire moves when you jack the axle, could be a bad unit bearing.
You can also measure toe. Measure from center to center on both the trailing edge and leading edge of the front tires. Down low is fine. Toe is usually about 1/8th inch more width across the rear.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #3 of 6 Old 07-06-2013, 12:02 AM Thread Starter
Skorchrock's Avatar
Had the truck up and checked for bearing issues....nothing. The toe should've been checked when it was in for the alignment. Since the left tire shows no wear...should I just tell them to set the right to the same specs?
post #4 of 6 Old 07-06-2013, 12:53 AM
alaskan155's Avatar
Quoted: 60 Post(s)
take it to another shop, outside of the tire tells me you toe is off , camber possible, bearings or balljoints would cause the inside to be bad.
i know big o will tell you what is worn out,
could always take a tape measure and measure the front and the back of the axle, center of the tire to center of the tire, the measurement should be the same. if not toe is off
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #5 of 6 Old 07-09-2013, 08:02 AM
i blew out my 35 in toyo cause they werent the correct load rating for a crew cab diesel..
05 f250 harley edition
studded, deleted
icon shocks with 6in fabtech
sinister coolent filter
sct and ficm tuned
blue spring mod
powermax turbo
175cc
airaid intake
4in turbo back exhaust
black windows
busaandy is offline
post #6 of 6 Old 07-11-2013, 02:07 PM
sounds like to much positive camber on right front [top of the tire leaning out] if u have the alignment print out look at the right front camber reading should be close to middle of the specs or very close to left front specs
albert1 is offline
