Best leveling kit for my '04 350?? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-02-2013, 03:26 PM Thread Starter
Hey guys I recently purchased an '04 Supercab Longbed Stroker. I am looking for the best overall leveling kit. The truck has 285/75/16's on it now and only the drivers side rubs.. I guess the spring is weaker than the right. Anyways I am looking for a true leveling kit.. I want my truck to sit level NOT high in the front. If anything I would rather it be just a little low in the front. I have seen a lot of these kits that are labeled leveling kits and the nose sits too high for my taste. I am wanting to run 305/70/16's on stock wheels for possibly some aftermarket wheels. I wouldn't mind running 315's if I could fit them. Anyways any input is great and pictures too!
SWMOoutdoorsman is offline
post #2 of 9 Old 07-02-2013, 03:36 PM
kclough's Avatar
I put on a 2.8 inch level kit and I'm running 315/75/16 and they rub a little once in a while at full lock in reverse. The truck looks slanted but its from the parking lot
kclough is offline
post #3 of 9 Old 07-02-2013, 03:39 PM
hdodt's Avatar
You could do 2.5" up front and if that's too high add a 1" block to the rear...
2006 F350 Lariat
EL CAT1 coolant and coolant filter.
95k miles. Oil cooler changed at 93k.
Oversized turbo oil drain tube.
hdodt is offline
post #4 of 9 Old 07-02-2013, 03:41 PM
kclough's Avatar
After I bought mine I wish I would of made mine. I have the spring pack and it would be very simple to make.
kclough is offline
post #5 of 9 Old 07-02-2013, 04:34 PM
Quoted: 908 Post(s)
Feedback Score: 3 reviews
Get X code springs. Gives a better factory look and no added parts to worry about.
Corey@CNCFAB is offline
post #6 of 9 Old 07-02-2013, 05:40 PM Thread Starter
Local off road shop here likes to use BDS add a leaf to the front to make it sit level.. And claim that guys really like it. Sounds like a pretty good idea. My thoughts were if that would work going with BDS 5500 shocks all the way around and a new stabilizer. My original Ranchos are pretty well wore out. I really wish I could see a picture of a truck with a BDS add a leaf.
post #7 of 9 Old 07-02-2013, 06:04 PM
Quoted: 908 Post(s)
For me I would much rather do the add a leaf and new u bolts over a spring pack. I seen others do the x code spring and I'm pretty happy with it. I believe the X were supposed to come on the snowplow prep trucks.
post #8 of 9 Old 07-02-2013, 06:18 PM Thread Starter
That's what I am thinking.. either a kit that has new springs or an add a leaf, either way I guess I will need an adjustable track bar to make it right I am assuming.
2004 350 SRW Supercab Longbed FX4
Mods:
ARP Studs
Black Onyx Gaskets
EGR Delete
XDP Coolant Filter
MBRP 4" Turbo Back
SCT SF3 Programmer
post #9 of 9 Old 07-02-2013, 06:46 PM
Quoted: 908 Post(s)
Depending on how high you go, you may not need an adjustable track bar. Its not a bad idea to with one though. It will give you more adjustment capabilities. Fwiw, I didn't with mine, I bought the newer 7.3 track bar for my e99 and it centered my axle perfectly.
