Bad vibes when going 70+ MPH - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-30-2013, 01:59 PM Thread Starter
I get this almost grinding sound, or vibes when I am going over 70 mph in my truck. It just got a new hub installed a month ago and the vibes are still there when I get up to 70 mph. This is driving me nuts, ive changed carrier bearings and all that ****. All my driveshafts are solid, no play. It sounds like its coming from under my feet. Whenever I get on the gas it goes away, but when i left off it comes back for a second. It goes and comes with acceleration once you get up to 70 mph. Thats why I originally thought it was with the driveshaft. I am running a 6" lift on 37 inch tires and I noticed im still running a single steering stabilizer. I was thinking maybe if this was bad it could be the cause of all my problems? I'd love to upgrade it to a dual stabilizer. If anyone can shed some light on this i'd appreciate it.
03 6.0 CCSB FX4
6" fabtech suspension lift 37" Toyo M/T's
03blackpowerstroke is offline
post #2 of 3 Old 06-30-2013, 02:47 PM
When was the last time that your tires were balanced? I have read several times over about that mystery vibration being tire balance.
I had my sway bar out for awhile and re-installing it helped with some bouncing that I was having around 50~55 mph.
Is your carrier bearing lowered? If so, was it lowered with a wedge shaped spacer or a square shaped? A wedge shaped drop would rotate (clock) the bearing and eliminate binding.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #3 of 3 Old 06-30-2013, 03:07 PM Thread Starter
the tires have 9k miles on them, so they should still be in balance. The carrier bearing is not dropped, its at stock height. and its not really a bouncing condition.. it doesnt increase or decrease when taking curves or anything. Im really stumped on this
03 6.0 CCSB FX4
