How much lift? - Ford Powerstroke Diesel Forum
post #1 of 16 Old 06-23-2013, 01:01 AM Thread Starter
KCCO
KMC_A55's Avatar
Question How much lift?
So here is a dumb question for y'all, or rather an opinion asking question...
How much lift do you guys think is on my truck?
The deal is I recently bought the truck with the lift already on it and am curious as to whether or not it is 4" or 6". I have done some looking and reading and it is definitely a Procomp lift. The tires that are on it right now are 35" and have probably 80% tread. I have looked at the installation guide for the Procomp lift kit and if i was looking at it correctly, the 6" has a little extra rear "lift block" that gets added in the leaf pack. Well my truck doesn't have that. So that would lead me to think that it is only the 4" kit. However, my 1998 Chevy k2500 on 12" of lift sits just as high as my new . Do the Ford's really sit that high with only 4" of lift?
So with that said, how can I know for 100% certain, that my lift is either a 4" or 6" lift.
Here is a picture of how my truck looks and sits right now. I can get a couple other pictures if it helps.
Thanks for the opinions!
2003 F-350 6.0L. CCLB, 6" lift on 35's, 100k miles: Sinister coolant Filter, Sinister EGR delete, Sinister boots, ARP studs, Diamond Eye 4" turboback exhaust, cat-elc, blue spring update, 6.4 banjo bolts, Edge CTS w/ EGT, SCT w/ Gearhead SRL+ tunes, S&B air intake, Atlas 80 FICM tune, water/meth injection, high idle switch, fog light mod, zoodad mod, 07 front, 07 dash, 08 taillights, 08 mirrors, 14 tailgate,
upfitters, Lock-Right Locker
KMC_A55 is offline
post #2 of 16 Old 06-23-2013, 01:46 AM
JSchuricht's Avatar
From the pic I would say it's 6" minimum, possibly 8" but it may just be the angle. What you should do is measure the front from the top of the wheel well to the center of the hub and compare it to a stock truck. It looks like you have the old grill which would indicate you have a 03 or 04 with leaf springs in the front. If it's one of those years then you can compare it to a 99-04 as the suspension will be the same in the front.
JSchuricht is offline
post #3 of 16 Old 06-23-2013, 01:51 AM Thread Starter
KCCO
KMC_A55's Avatar
Correct my friend, it's an 03 with leafs and the worst riding vehicle I have ever ridden in. lol. I will take a measurment when I get home and post it up.
Any body else with a stock height truck able to post up their measurments so that I have a base number to compare to? I dont know anybody else with my body style f250/f350. I guess I could measure some random truck I see in a parking lot.
KMC_A55 is offline
post #4 of 16 Old 06-23-2013, 02:41 AM
KCCO!!
kells17's Avatar
I was unsure of mine as well when I purchased mine. Took it to an off-road shop and they took the serial number off the shock (it was painted) and looked it up. Depending on the shocks you are running, it should coincide with the lift you have. Make sense? I took the guy less than 2 minutes to figure it out.
CHIVE ON!
2004 F-250 Lariat CCSB
Studded, Deleted, Cold Air, Fog Light Mod,
IPR HF Coolant Filter, High Idle, Atlas 40 FICM,
CCV, Edge Insight CTS, ZooDad, BPD Oil Cooler,
4" Banks Monster Exhaust, Fumotos, 05 Harley Headlights,
Blue Spring, Kill Switch, 03 Turbo and 6.4 Banjo Bolts
VA Strokers
757 Diesel
kells17 is offline
post #5 of 16 Old 06-23-2013, 08:37 AM
shawnb99's Avatar
Just ask one another ....same set ups for the years....
What is the height of frame over axle center line...
Post that and we can be for certain what lift you have.
04 F-250 CCSB 4X4 6.0L Auto, tweaked by GEARHEAD
follow link to truck for sale
shawnb99 is offline
post #6 of 16 Old 06-23-2013, 09:27 PM
There is no way that is a 4in lift, it sits way too high. Its a 6 or 8 and I really think its 8, at least in the rear.
I have 5 inches of blocks in the rear with 315s on 16in wheels and stock springs and its about level with the top of the wheel.
I have approx 5.5 in the front and the bottom of the door is pretty much at the same height as the wheel as well.
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
post #7 of 16 Old 06-24-2013, 02:07 AM Thread Starter
KCCO
KMC_A55's Avatar
Checking the shock serial/model number isn't a bad idea. That could get me close to figuring it out. Good call!
Thanks for the reply's guys, one way or another we are going to get to the bottom of this mystery. I measured from the center of my hub to the bottom lip of my front fender, and the distance is 31". The same measurement on the rear is 31.5". I will have to look at the Procomp website today and see if they offer an 8" option and then compare the instructions images to what my truck has and see. I guess I didn't even think that it would possibly be that high.
I'll be sure to post back and let everybody know what I discover.
KMC_A55 is offline
post #8 of 16 Old 06-24-2013, 11:12 AM Thread Starter
KCCO
KMC_A55's Avatar
So I measured one of the contractors f350 at work. It's an 03, but not a diesel, I don't know if that matters.
But the measurements from that truck were 24.5" in the front and 27" in the rear.
Given that information I am guessing that its a 6" lift on my truck, and the previous owner just didn't have the extra block in the rear installed because they must have liked the nose high look, I dunno.
KMC_A55 is offline
post #9 of 16 Old 06-24-2013, 11:30 AM
ZMANN's Avatar
Quoted: 1579 Post(s)
did u measure from a fixed point on the axle to a fixed point on the frame on both trucks ?
that takes the tires out of the measurement
We Miss you Ronnie
ZMANN is offline
post #10 of 16 Old 06-24-2013, 11:45 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
I had this same predicament with my truck the PO told me it had 13 inches of lift and i sure believed it but then i got the urge to actually measure it and i measured it center of axle to top of bed rail and compared that to my dads 02 gasser and it was only 8 inches so i dont know where he was getting 13 inches i guess every guy exaggerates just a bit
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
