Front Axle Problem - Ford Powerstroke Diesel Forum
post #1 of 1 Old 06-21-2013, 10:51 AM Thread Starter
Front Axle Problem
So on the truck listed in my sig I am doing ball joints and new tie rods, etc. I took everything apart and when I go to remove the snap ring on the axle, get that off and.
no thrust washers behind it what the hell
does that mean someone was in there before me and forgot to install them back?
I have no idea
I guess I will pull apart the other side and see if it has the washers behind the snap ring
any info would be appreciated
http://youtu.be/_McGEdeVL-Y
2006 F-250 PS CCSB King Ranch
6" Fabtech Lift
Bilstein 5100's
35" Falken Rocky Mountain AT/S on 20" Pro Comps
EGR Delete - Performance Machine mfg.
Updated Oil Cooler
6.4 Banjo's
Updated Larger Turbo Oil Drain Tube and Feed line
"Blue Spring"
AFE Stage 2
SCT Livewire - "Looney Tune"
4" Turbo Back Straight Pipe
Updated Dummy Plugs & Stand Pipes
Roll-N-Lock Bed Cover
Train Horn (get off your cell phone horn)
Zoodad
more to come as the hours go by...
TheOne is offline
