BDS 6" 4 Link Problems - Ford Powerstroke Diesel Forum
post #1 of 21 Old 06-19-2013, 07:16 PM Thread Starter
First 6.7 PS Destroyer
mysticblu999's Avatar
Quoted: 2 Post(s)
I need your help. I just installed a BDS 6" 4 link with fox shocks and dual stabilizer. I had a BDS 4" drop bracket kit with no stabilizer and regular shocks, and it drove as good as stock. Now my truck drives and rides like crap. It throws me around left and right, which
I'm assuming is because of the 4 link. I was thinking about a dual shock kit, or just some better shocks that will keep this thing from throwing me around. I don't mind to bounce up and down, but left and right I cannot tolerate. Next, it likes to wonder around. I was shocked that it seems like the dual stabilizer kit with 9500s did nothing. My truck was already starting this before with the 4" lift so I just assumed that the factory stabilizer needed replaced also. Maybe it needs a better sway bar, I don't know. I've already got $4600 in this kit with install, I expected much better. The 4" kit was way better but did not clear my new 37s very well.
The main thing I want, is for this thing to stop flopping like a damn fish, and drive like the nice 4" kit did.
2011 F250 6.7 4x4 CC Lariat
6" 4-link BDS
22" Fuel Hostage
37" Toyo MT
H&S BLACK MAXX,
5" MBRP straight pipe
AMP Steps
Truck pics ---->
mysticblu999 is offline
post #2 of 21 Old 06-19-2013, 09:37 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
Try going back a degree or two in the negative caster direction. I was having some death wobble issues and moving it back negative some tightened that up. Now I have fabtech radius arms but the same physics apply.
Now if you have any play in your drag link you are going to feel it more with a 4 link setup. The radius arms give some side to side control but 4 link gives none whatsoever.
You are going to need to tune it in, the 4 link will give the best ride results once it's dialed in. Be patient you may need to bring it to a shop that has experience with them if you can't get it where you like it.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #3 of 21 Old 06-19-2013, 09:45 PM
ZMANN's Avatar
Quoted: 1469 Post(s)
throwing you around is interesting ?
I just threw a Rize 4 link on mine to dump the radius arms and drop brackets and had no negative side effects
I know some 4 links can give a sway feel not sure if BDS was one of them ?
We Miss you Ronnie
ZMANN is offline
post #4 of 21 Old 06-20-2013, 06:13 AM
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
Are you sure everything is tight ? Look at the drop down drag link bracket and everything with a bolt. lol
Being it's a 2011 I wouldn't think you would have worn ball joints or much of anything, but never say never.
Are your links adjustable or do they look like pic above?
Have you had it aligned ? Correctly ??
7" Icon/Carli Lift
Atlas40
mhatlen is offline
post #5 of 21 Old 06-21-2013, 07:53 AM Thread Starter
Quoted: 2 Post(s)
Just had everything tightened up. That should help. I had 4000 miles on it before it was re torqued, and I have not drove it yet. Fingers crossed.
As for the wondering around, is there a way I can add some caster? The 4 link is non adjustable from what I can tell.
As far as throwing me around, I'm positive its just because the front axle articulates so much better, which is great for off road, but when I'm on road and the pavement is not level, it feel very weird. Like the axle is flexing. I was hoping some heavier valved shocks would slow it down. I'm still learning about truck suspension.
6" 4-link BDS
22" Fuel Hostage
37" Toyo MT
H&S BLACK MAXX,
AMP Steps
Truck pics ---->
post #6 of 21 Old 06-21-2013, 08:37 AM
Skyd Ram's Avatar
Quoted: 131 Post(s)
You will get more body roll with a 4-link but the truck shouldn't be having a mind of it's own.
What is the caster reading on your truck after you got an alignment?
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
post #7 of 21 Old 06-21-2013, 09:24 AM Thread Starter
Quoted: 2 Post(s)
I have lost the print out. I may want to go back and have it checked again.
6" 4-link BDS
22" Fuel Hostage
37" Toyo MT
H&S BLACK MAXX,
AMP Steps
Truck pics ---->
post #8 of 21 Old 06-24-2013, 05:02 AM Thread Starter
Quoted: 2 Post(s)
After driving it some more, I'm thinking the caster is off. What should I be at?
Sent from AutoGuide.com App
6" 4-link BDS
22" Fuel Hostage
37" Toyo MT
H&S BLACK MAXX,
AMP Steps
Truck pics ---->
post #9 of 21 Old 06-24-2013, 11:31 AM
Pure Perf's Avatar
We like to see 4 to 4.5 degrees on Super Duties!
JP
www.pure-performance.biz
Pure Perf is offline
post #10 of 21 Old 06-24-2013, 12:01 PM Thread Starter
Quoted: 2 Post(s)
Thank you I'm taking it in soon!
6" 4-link BDS
22" Fuel Hostage
37" Toyo MT
H&S BLACK MAXX,
AMP Steps
Truck pics ---->
