will GM wheels fit? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-20-2008, 06:48 AM Thread Starter
will GM wheels fit?
I have a 91 250 4wd. I am looking for a more modern wheel. Mine have the 8 x 165 mm lugs. All the new Fords have 8 x 170 mm lugs. I see that most GM's have the 6.5 lugs (should be same as 165mm??) Will the GM wheels fit? My truck is lifted 4" so I also assume the offset shouldn't matter. I believe my truck came with 0 offset.
Thanks
Howard
nohairracing is offline
post #2 of 2 Old 03-20-2008, 07:15 AM
a truck
Matt P's Avatar
Your lug patter in actually 8x6.5 and all the GMs up to 04 are also 8x6.5 so you should have no problem fitting GM wheels on.
03 king ranch w/ a cummins
Matt P is offline
