99.5 F350 Front Suspension - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-10-2013, 10:48 AM Thread Starter
Power Stroker
stroking 7.3's Avatar
Quoted: 2 Post(s)
Send a message via Skype™ to stroking 7.3
Was under the truck this weekend and noticed a few things show on the front end steering and suspension needing repair or replacement. Not sure what everything is called and was wondering if anyone had a diagram. Also where is a good place to get suspension parts, don't want the cheap stuff and can't afford the over priced. Quality parts for the money. 99.5 F350 4WD 7.3L
Thanks,
Bobby
'99.5 F350 4WD Crew Cab Long Box,
Foil Delete. Custom Airaid intake. Riffraff Boost Fooler. Riffraff FRx. Riffraff HPOx. Strictly Diesel In Tank Kit. Lifter Pump. F650 Dash Kit. Issopro Fuel Pressure and Trans Temp Gauges PHP Phoenix Tuner, Xenon Air Dam. Swamps Stage 1 Injectors. Train Horn.
stroking 7.3 is offline
post #2 of 5 Old 06-10-2013, 01:08 PM
Not sure about a diagram but I get all my parts from tousley ford or rockauto. Great prices on oem and/or aftermarket parts.
Can you post pics and we can help you with whats what?
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
post #3 of 5 Old 06-10-2013, 02:38 PM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Maybe this will help a little.
We carry Danatrac ball joints.
Rest I'd look at XRF's.
CT Performance, Inc. is offline
post #4 of 5 Old 06-10-2013, 03:57 PM Thread Starter
Power Stroker
Quoted: 2 Post(s)
I know one thing is going to be the "sway bar end links" and pretty sure I have a ball joint that is showing wear. Been raining all evening and I won't be able to take pictures for a couple of days.
Thanks,
Bobby
post #5 of 5 Old 06-12-2013, 08:59 AM Thread Starter
Power Stroker
Quoted: 2 Post(s)
Tie Rod Ends I knew what the tie rod was, I just didn't know what to call the things at the end. Thought they would have the word "joint" in the name.
Thanks,
Bobby
