350 springs on 250?? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-09-2013, 02:45 PM Thread Starter
powerstrokecrzy's Avatar
Quoted: 256 Post(s)
Got the opportunity to get some 350 rear springs at a good price. Will they swap onto my 250 without any problems. I'm wanting the little stiffer suspension for when I haul and tow, I currently get more sag than I'd like.
05 250. Lariet. 4x4.
arp studs w/oem gaskets & all updates
Warren 175cc/stock sticks
Egr delete
Zoodad
New oil cooler
Coolant filter w/ zerex ec-1(homemade)
4" turbo back, straight piped
SCT livewire (running TSD SPD)
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Ccv reroute (dump to atmosphere)
Air Horn Kit
high idle
Pro comp "bullet hole style" 17" w/ 35" nitto trail grapplers
powerstrokecrzy is offline
post #2 of 10 Old 06-09-2013, 03:47 PM
JustinOOO9's Avatar
Quoted: 521 Post(s)
Garage
measure your eyes on your truck the only thing different is weight rating that im aware of you can look at your spring code on door jam. are they stock springs? if they wont work for you let me know i have an 8in and want lower height.
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is online now
post #3 of 10 Old 06-09-2013, 07:30 PM
Rear springs are the same, just different capacity ratings. However as mentioned, you will want to check spring codes. I believe 99-07 use the same springs.
Justin, I have a set of 03 F350 springs if you're interested. I have both front and rear springs. Rears have overloads and I also have a brand new set of top overloads. There is nothing wrong with the springs. LMK
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
post #4 of 10 Old 06-10-2013, 05:14 AM Thread Starter
Quoted: 256 Post(s)
Thanks guys, what am I looking for in the spring code? That they are the same or what???
Egr delete
Zoodad
New oil cooler
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Air Horn Kit
high idle
post #5 of 10 Old 06-10-2013, 06:43 AM Thread Starter
Quoted: 256 Post(s)
Ttff spring code, if that means anything special
Egr delete
Zoodad
New oil cooler
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Air Horn Kit
high idle
post #6 of 10 Old 06-10-2013, 01:12 PM
Im not familiar with all the spring codes. Ill see if I can find the capacity ratings for ea code after work.
Do you know what the codes are for the replacement springs? We just want to be sure you are not wasting money on the same springs
INFRNL is offline
post #7 of 10 Old 06-10-2013, 02:00 PM Thread Starter
Quoted: 256 Post(s)
Not sure, haven't got them yet. I know they're from an 06 350 dually, so I'd imagine they would be stronger. mine have got to be the softest of the options cause I get quite a bit of sag when loaded.
Egr delete
Zoodad
New oil cooler
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Air Horn Kit
high idle
post #8 of 10 Old 06-10-2013, 02:31 PM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Non dually..get B codes only difference from yours is the top overload..which requires the frame stops. If you have top overloads now they are the same as a f350. Springs will still drop 2"+- before they hit the frame stops.
Air bags best option, using daystars new bag cup
CT Performance, Inc. is offline
post #9 of 10 Old 06-10-2013, 05:21 PM
Dually springs will definitely do the trick, I just hope they are not too stiff when unloaded. My dually doesn't seem too bad. I think it rides pretty well for the big truck it is
INFRNL is offline
post #10 of 10 Old 06-10-2013, 05:52 PM Thread Starter
Quoted: 256 Post(s)
No to worried bout it being to stiff. Buddy if mine has a short bed 350 with overload springs and all and it doesn't seem bad at all. Plus got the wife's air ride armada to haul the family around in.
Egr delete
Zoodad
New oil cooler
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Air Horn Kit
high idle
