Bilstein 2.25" Leveling Kit with 5100's and coils to replace 2.5 spacer...? - Ford Powerstroke Diesel Forum
post #1 of 19 Old 06-04-2013, 09:54 PM Thread Starter
So my 05 has 136K miles and a 2.5" leveling spacer under the coil... The truck rides pretty rough on 35x12.5x18 M/Ts with 50psi in the tires (way worse with 60+)
SO I have had 5100 adjustables on a chevy that I liked in the past and found this kit that levels the truck 2.25" and comes with the 5100s and also new coils. Sweet price of 235.00 shipped!! Not bad if its a better ride! Surely the coils and stock 'ranchos' are due to be replaced anyway! I will do the back 2 later down the line.
Would this be a decent ride improvement?
I do plan to downsize to the 295/70/18 Nitto A/Ts when these M/Ts wear down but they wont be too much smaller... Maybe a smoother ride, less noice and 0.5MPG gain!!!
TxOutlaw is offline
post #2 of 19 Old 06-24-2013, 05:15 PM Thread Starter
Buncha views, no tips?? LOL
If not this set up, what would be another good option without breaking the bank?
TxOutlaw is offline
post #3 of 19 Old 06-24-2013, 05:54 PM
I do not have any answers for you but....
The rubber spacers should have no effect on the ride quality. Ive heard the rancho shocks suck on these trucks.
Ive heard good and bad about the 5100s. Ive run them without issue. I now have 5160s in the front and 5100s in the rear. The 5160s definitely ride better but cost approx $100 more ea.
Since you have an 05, you have a lot of options for your suspension.
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
post #4 of 19 Old 06-25-2013, 11:19 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
You will also need castor shims and a adj track bar.
CT Performance, Inc. is offline
post #5 of 19 Old 10-03-2013, 03:37 PM Thread Starter
I think I have decided on 5100's all around and keeping the 2.5" spacer. I do not see a shock that is for my situation. I see the front shocks for 0-2" of lift then one for 4" but no in between.
I should be fine with 0-2" lift shock, right??
Thanks for the replies!
TxOutlaw is offline
post #6 of 19 Old 10-03-2013, 03:55 PM
deanbrada's Avatar
The 5100's will definitely be better than the stock Rancho's. Put them on my 08 dually when I leveled it out. Amazing difference. There was a thread that had some additional information that might be good for you. Not sure how to link the thread on here but here is the html link.
Bilstein vs. Tuffcountry vs Icon 2" Leveling kit
deanbrada is offline
post #7 of 19 Old 10-04-2013, 08:10 PM
Scott701's Avatar
I would craigslist the spacers. The bilssteins level out our f150s real nice, don't c why they wouldn't be good for the 250. I don't like the idea of spacers. I know its a youtube infomercial, but check this out... :
It makes a lot of sense.
Everything I say is based on my own knowledge, research, findings, and experience. If anything I say is incorrect, incomplete, insulting, threatening, or stupid, I apologize beforehand. I am here to learn and spread information.
Scott701 is offline
post #8 of 19 Old 10-04-2013, 09:59 PM
I have an 05 F250 6.0 that I'm going to level in the next couple months. Still having a hard time choosing what the hell I'm going to do yet though.
Narrowed it down to the Bilstein and an Icon, cause I'm starting to think 2.5" will look better.
I just found a kit from PerformanceTruckProducts, which I'm leaning towards. Comes with the Icon 2.5" leveling coils, you can choose whether you don't want the Bilstein shocks, just fronts or front and rear 5100's, an Icon adjustable trac bar, coil spacer(not sure why you'd want one if you're getting leveling coils?), the Icon dual steering stabilizer, adjustment cams and the option for no blocks or 4 or 5" rear blocks, which 4 and 5 inch seem ridiculous for a 2.5" level.
What I'll probably do is get this kit, with just the coils, adjustment cams, bilstien 5100's all the way around, comes out to be 795. Gonna do the F350 rear blocks.
Not sure if I need to get an adjustable trac bar or not, I've read through tons of threads stating you don't need one for a leveling kit and I've read some saying you do.. That being said my whole trac bar assembly has about 1.5k miles on it so I'm not sure if I need it or not..
I've thought about doing the Bilstein dual steering stabilizer as I'd be going up to 35's, but once again I've read it's not needed unless like 37"+ tires and I've read of people using with stock format to 35" tires and having good results..
Alpha Male is offline
post #9 of 19 Old 10-06-2013, 03:32 AM
Quoted: 11 Post(s)
That is an amazing deal, where did you find that?
David Frost
2005 F250 Harley 6.0 CCSB
Towerguy is offline
post #10 of 19 Old 10-06-2013, 05:48 AM Thread Starter
Amazon if I recall. I will check my saved pages when I return home.
TxOutlaw is offline
