Custom adjustable track bar anyone? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 06-03-2013, 07:14 PM Thread Starter
jdereu's Avatar
I made my 2000 a set of lift shackles that will give me about 1.5-2" lift in the front. My question is will I need a track bar and if so has any one customized the stock one. If so how did you guys do it
2000 Ford F-250, Crew Cab Long Bed 4x4, Automatic Transmission, Ts 6 Position, 4" MBRP Exhaust, DIY Intake, Pillar Guages, CCV Mod
jdereu is offline
post #2 of 15 Old 06-04-2013, 09:55 AM
I would say yes, you want an adj track bar any time you lift the front.
Ive seen a thread recently where a guy modded his stock bar and had links to the parts used.
Need to cut and thread the stock bar and get one of the adj couplers similar to the drag link one.
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
post #3 of 15 Old 06-04-2013, 10:53 AM
My experience would say no because it's a 2000. I had a 2" add-a-leaf under my 2003 for awhile, no changes to track bar, no issues.
Sent from my LG-VS700 using AutoGuide.Com Free App
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #4 of 15 Old 06-04-2013, 10:56 AM Thread Starter
jdereu's Avatar
Do you have the link to the write up?
jdereu is offline
post #5 of 15 Old 06-04-2013, 10:59 AM
NotStock's Avatar
It doesnt really need to be adjustable unless you may change it down the road. If your doing the work yourself, simply cut the track bar and sleeve another larger tube on the outside of it. You dont want there to be any tension on the track bar when the vehicle is sitting there at rest.
If you decide you dont want to deal with making one, we have a beefy track bar that uses 1" heims. We have a few instock and they run $225 plus shipping.
Precision Metal Fab
Trevor Hall
(520)465-7971
NotStock is offline
post #6 of 15 Old 06-04-2013, 06:35 PM
Let me see if I can remember where I saw it. I will post as soon as I find it
I have Trevors adj trac bar and it is definitely beefy. The heims are huge!!!
The only issue I had was the bushings were too wide for the upper mount. I tried and tried to get it in. I had to carefully file the outside edges of the bushing till I could tap the heim in with a dead blow hammer.
In the end, it was well worth it to me, cause I am extremely limited on time.
Trevor (PMF) has some great quality products available at great prices imo. Thanks Trevor!
INFRNL is offline
post #7 of 15 Old 06-04-2013, 06:42 PM
ZMANN's Avatar
Quoted: 1793 Post(s)
to make the OEM adjustable you would need to cut it
and make it sized and round ( they are not like bar stock and nice and round ) so a DIE could thread each side not to mention left right threads and coupler if you wanted it adjustable without removing it
or at least thread 1 side for the coupler and jamb nut
PMF for 225 FTW
or cut and weld for 0 monies
We Miss you Ronnie
6.0 flush pdf
ZMANN is online now
post #8 of 15 Old 06-04-2013, 07:36 PM
NotStock's Avatar
Sorry about the wider heim. We got an odd ball batch from QA1 that was .04 oversized on the ball and it messed up the mounting width as you experienced. It was something I had never run into, so up till then we never even checked them. Now we do. Again, sorry for the added install time. But Im glad you were still pleased with our product!
Precision Metal Fab
Trevor Hall
(520)465-7971
NotStock is offline
post #9 of 15 Old 06-04-2013, 08:12 PM
No problem, and thanks for the explanation, makes sense now. All the other products I have of yours have been excellent quality, stout as h*ll and trouble free installation.
On a side note for anyone interested, Trevor is always willing to help and answer any questions even during my retarded moments
As to the op, im on the hunt for that link, can't find it for some reason
INFRNL is offline
post #10 of 15 Old 06-05-2013, 07:36 PM Thread Starter
jdereu's Avatar
Well started installing it today. Do need to make my track bar longer as well as my sway bar links. I'm going to cut the track bar mount it on the truck with the sleeve jack up the axle a little then weld it up. Problem solved
jdereu is offline
