Popping noise in front end - Ford Powerstroke Diesel Forum
post #1 of 11 Old 05-28-2013, 11:12 AM Thread Starter
SuperrStroker's Avatar
I've noticed when I pull in a driveway or something similar to that, I get a pop/clunk in my front end on the passenger side. All of my ball joints seem to be good, could it be a shock?
21.5" Curved DPG LED Light Bar, Morimoto Mini H1 Projectors, Kenwood DDX770, 37X13.50R20 Toyo MT Open Country, DropStar 645B 20X10, ProComp 8" radius arm lift kit, Super Panty Dropper, Diamond Eye 5" turbo back, Triple Gauge Pod with AutoMeter Pro Comp Ultra Lite EGT, Boost and Trans, Studded, EGR Deleted, Powermax, Coolant Filter, S&B Air Filter, DHDP Stage 1 Trans
SuperrStroker is offline
post #2 of 11 Old 05-28-2013, 02:25 PM
If you haven't already, jack the tire off the ground... Sure sounds like ball joint... I could not get any play with the tire on the ground, but was loose as heck off the ground...
TxOutlaw is offline
post #3 of 11 Old 05-28-2013, 05:29 PM
Send a message via Skype™ to bwmtnbiker
It could be the track bar as well.
-Brian
2003 F-250 6.0L - Lariat King Ranch
-300k+ miles and still strong
Current Mods
-6.5" Pro-Comp lift
-Edge CTS
-SCT X3 (Tuned by Vivian
-4" Turbo Back Silverline Exhaust, 5"tip
-Blue Spring Mod
-Sinister Coolant Filter
-Oil Cooler
-Sinister EGR Delete
-OEM Cab Lights
Wants/Soon
-ARP Studs
-MTW Stage 1 or Hybrid
-6.4 Banjo Bolts?
bwmtnbiker is offline
post #4 of 11 Old 05-31-2013, 10:51 AM
This thing is a little bit surprising that making noise. There are vary few common one's that give this type complaint. And if really does then you are one of them. Consult some qualified technician to recognize the problem in proper way not the ordinary junk.
Jason001 is offline
post #5 of 11 Old 05-31-2013, 11:30 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
I have the same popping in my front end and its only when going slow and turning into a parking lot or driveway. I just had my whole front end gone over after my accident, he said everything was tight. then after driving it i noticed the popping and i went back and asked him and he said its common for these truck to have the bushing go bad in the steering box and it causes that popping sound. he said its ok to drive for awhile with it like that, i plan to replace it one of these days
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #6 of 11 Old 05-31-2013, 01:38 PM
Rodslinger's B1TCH
mine has a loud pop from the front driver's side that is a loose body mount bolt. I haven't got around to tightening it yet. it's supposed to be really common the superduty.
steve604 is offline
post #7 of 11 Old 05-31-2013, 01:53 PM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 275 Post(s)
As TXOutlaw stated, jack up one side of the front end, until you have enough room to get a nice big pry bar under the tire, and lift up on the pry bar, while looking for any movement the ball joints, a very common problem, even on low mileage superdutys. When my ball joint were bad, when I bought it, it didnt make any noise. It did however develop a significant pop pulling in and backing out when my sway bar bushings were bad. As bwmntbiker stated, check your track bar bushings
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW FOR SALE!!
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
post #8 of 11 Old 06-02-2013, 04:23 PM Thread Starter
Thanks everybody. I checked the ball joints when I did my leveling kit. I'll check the track bar and body mounts this week when I do my quad fog lights.
post #9 of 11 Old 12-26-2013, 08:48 AM
What did you find?
2006 cc 4x4,Rotella 5-40,Amsoil bypass filter Dieselsite coolant filter, edge evolution, K&N air filter, high idle mod, zoodad mod, 60 gallon Titan Tank, blue spring kit, Airlift 5000 bags, Bilstein hd shocks, MBRP 4 inch st pipe turbo back, welded egr cooler
rowcoach is offline
post #10 of 11 Old 12-26-2013, 09:28 AM
Mine was doing the same. Looked around for months trying to figure out what it was' replacing items along the way to solve the problem.
Replaced the body mounts and boom problem solved. Good luck
2006 F-250 PS CCSB King Ranch
6" Fabtech Lift
Bilstein 5100's
35" Falken Rocky Mountain AT/S on 20" Pro Comps
EGR Delete - Performance Machine mfg.
Updated Oil Cooler
6.4 Banjo's
Updated Larger Turbo Oil Drain Tube and Feed line
"Blue Spring"
AFE Stage 2
SCT Livewire - "Looney Tune"
4" Turbo Back Straight Pipe
Updated Dummy Plugs & Stand Pipes
Roll-N-Lock Bed Cover
Train Horn (get off your cell phone horn)
Zoodad
more to come as the hours go by...
TheOne is offline
