Really hard to turn - Ford Powerstroke Diesel Forum
post #1 of 13 Old 05-27-2013, 12:50 AM Thread Starter
Really hard to turn
Hey guys i got another question. I a 2006 f350. When i am parked or triyng to park man.......its so hard to turn my wheel left or right. It feels like i have no power steering. But when i am on the road driving it feels normal and i can turn the wheel easily. Is this normal guys? Thx for ur help.
darren808 is offline
post #2 of 13 Old 05-27-2013, 01:37 AM
BIG Laing's Avatar
Have you ever driven a vehicle without power steering? It is identical to what you are describing.
Is it normal? Not if you have a properly functioning truck with power steering.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 13 Old 05-27-2013, 03:23 AM
mustangmike6996's Avatar
check your fluid level. might be needing a pump if the level is good depending on output pressure. does it clunk or click?
I have seen crappy balljoints/tie rod ends cause hard steering as well
mustangmike6996 is offline
post #4 of 13 Old 05-27-2013, 04:19 AM
BubbaJ's Avatar
When your in park, Rev up the engine a little, and try turning the wheel... Just rev it to like 1,000 or 1,250.. Don't go crazy... If your having a hard time turning the wheel at no speed your most likely experiencing a failing/failed pump. Rev'ing the engine up some could bring your line pressure up enough to assist in turning, If it it does than thats your culprit..
If it does not, I'd look into ball joins/Tie Rod/ Pitman arm, all of your front steering components. and see if anything feels excessively wobbly.
Uhhh... Wait... What...
2005 F-250 PowerStroke 6.0 ** SOLD***
BubbaJ is offline
post #5 of 13 Old 05-27-2013, 10:53 AM
jetjock15's Avatar
Quoted: 111 Post(s)
Do you have oversized tires? I have added hydraulic steering to move my big tires. Stock size tires should not be an issue.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #6 of 13 Old 05-27-2013, 11:07 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Power steering pump is shot. I had this exact same problem with mine before I swapped out the pump for a new one. Now I can turn the steering wheel with one finger just sitting in the driveway.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #7 of 13 Old 05-27-2013, 11:21 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 888 Post(s)
Feedback Score: 6 reviews
^^^ What Bryan said. My old pump did the same thing but also whined a bunch, so I KNEW mine was shot.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #8 of 13 Old 05-27-2013, 11:53 AM Thread Starter
Thx for guys help. How much does a new pump cost? Kind of early for the pump to out eh? Only has 62k on it.
Sent from AutoGuide.com App
post #9 of 13 Old 05-27-2013, 11:54 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
It happens. Mine only had 130K and went out. They are around $120 from Ford. Only get them from Ford. Don't buy them from Vatozone or anything like that.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #10 of 13 Old 05-27-2013, 12:39 PM Thread Starter
Ok thx man for the tip.
