4 inch lift, now pulls right - Ford Powerstroke Diesel Forum
post #1 of 11 Old 05-26-2013, 09:29 AM Thread Starter
Ok so I've got a '01 F350 4x, just had Dunbar Spring here in Phx do a rearch, aal, and adjustable trackbar to level me up. Brought the front up a nice four inches. Right when I picked it up it pulled to the right. I brought it home, installed Icon extended sway bar links and Icon 2.0 shocks. Took it to get an alignment and they said everything is perfect, maybe a tire. So to Discount I go and tires are fine, did a rotate an balance, still pulls to the right. What could be causing this?
2001 F350 CC LB SRW 4x4 Lariat
Autometer Boost, Trans, EGT
Firstone Ride Rite/Onboard compressor
DIY 6637
Icon 2.0
Dunbar Spring 4" level, adjustable trackbar
265/65/16 BFG Commercial
Tundra2Powerstroke is offline
post #2 of 11 Old 05-26-2013, 09:46 AM
Betaracer's Avatar
Quoted: 15 Post(s)
It pulls to the right, or the steering wheel is pointing left and when you have it centered it steers right?
2016 F-350, FX4, CCLB, 6.7PSD, 7" OUO/ICON/FOX lift, 37x13.50-18 Toyo MT
Betaracer is offline
post #3 of 11 Old 05-26-2013, 10:05 AM Thread Starter
Pulls to the right, let go of the wheel and I change lanes. Happens no matter what road and how much crown. Had the steering wheel centered so m good there.
DIY 6637
Icon 2.0
post #4 of 11 Old 05-26-2013, 10:27 AM
Does the "pull" change when you brake? lightly? or firmly?
Is it a steady pull?
As in you can hold the wheel to the left steady in one place?
Or does it wonder around?
And at all speeds? give or take.
2006 built 05/05 XLT CC DRW PSD. Captain chairs, sunroof, polished aluminum wheels, 6speed, manual 4x4. 285K miles with 130K problem free miles on new engine.
RatherBNtheWoods is offline
post #5 of 11 Old 05-26-2013, 11:58 AM
Term3's Avatar
I'd say the trac-bar length is not set correctly or that the adjustment has backed off. Did they use red thread locker?
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #6 of 11 Old 05-26-2013, 06:46 PM Thread Starter
Pulls constant and steady and doesn't change with braking and no wandering.
DIY 6637
Icon 2.0
post #7 of 11 Old 05-26-2013, 06:50 PM
BIG Laing's Avatar
I would be taking it to a different alignment shop. Or go back to your first alignment shop and have them give you the results.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #8 of 11 Old 05-27-2013, 02:20 AM
mustangmike6996's Avatar
ask for a printout of the alignment results after its done... I would also make the shop to it again. If you pay for an alignment you shouldnt have a vehicle that pulls.
As for the numbers being "in the green" (as seen on the screen) .... pay attention to the cross, it is still possible to have it "in specs" and wear tires.
if it didnt pull before the lift and you didnt change tires, id say they didnt install it correct. all bolts are supposed to be inserted, tightened, torqued in the loaded (tires on the ground) position. if they did it in the air id say that is where your problem will start. drive it around the block and over a few bumps, loosen all the bolts without removing them to ease the stress of the suspension and retorque. see if anything changes. then take it back for another alignment
mustangmike6996 is offline
post #9 of 11 Old 05-27-2013, 07:34 AM
I have done several lift configurations under my 2003 and it never acted funky when I was done. While doing all of this monkeying around with my front end I found out that on a 4" lift, you can flip the sway bar mounts to the bottom of the frame and use the OEM end links.
How do you know that the length of the adjustable track bar is correct? Have you had a 4 wheel alignment done to ensure both axles are pointing in the same direction? Your front alignment can be dead on, but it means nothing if the axle is pulled to the left because the track bar is too short.
PERSONAL OPINIONS, I have seen rearched OEM springs sag, and I think that at 4" of lift, a track bar drop bracket and a dropped pitman arm should be used.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #10 of 11 Old 06-17-2013, 08:58 AM Thread Starter
Update
So adjusted track bar so axle is nice and center and that didn't change a damn thing. Went back to Network Alignment, they put in the adjustable cam and now everything is nice and straight. What a headache that was. Thanks everyone for all your suggestions.
DIY 6637
Icon 2.0
