Lift suggestions - Ford Powerstroke Diesel Forum
post #1 of 16 Old 05-25-2013, 05:50 PM Thread Starter
Lift suggestions
I have an '03 f-350, right now I have the rough country 2.5" leveling kit on it with 35x12.50 mickey thompson ATZs on 17x9 Mickey thompson classicIIs I have been wanting to go bigger, Was thinking of a 4" possibly 6" this is my daily driver and don't wanna get too big with it. Any suggestions of lifts with tire and wheel sizes? Pictures would be cool too. I do like the Skyjacker lifts as they have some that have replacement leaf spring fro front and rear.
powerstroke'n is offline
post #2 of 16 Old 05-25-2013, 06:02 PM
Powerstroke_21's Avatar
Sub'd I need some pics on different lifts/tire combos as well. I'm thinking about a 4" but not sure what size tires
Sent from AutoGuide.com App
Jarrette
1999 F350 ecsb 4x4 130k miles.
Mbrp 5" exhaust
TS 6 pos chip with Gearhead tunes
Auto Meter CS Series gauges (boost, pyro, trans temp)
S&B Intake
Aftermarket wastegate controller
Mods to come:
Crank case vent
Hutch and harpoon mod (if not already done)
1997 F250 rclb 4x4 gasser
Going to do a 12v swap in it tho
Powerstroke_21 is offline
post #3 of 16 Old 05-25-2013, 07:09 PM
t-ray-4ray's Avatar
Quoted: 94 Post(s)
Attachment 116593 this is my 01 with a zone 4 inch lift and 37 inch bfg baja military tires on eagle alloy 16.5/10 inch rims I recently added a set of homemade lift shackles in the front due to rubbing on the fender liner here I that pic Attachment 116601 it's a little nose high but I like that look but I used to have 35s on stock rims for a daily driver I use my truck allot in and out all day and with the 6 inch and 37s it's a slight pain in the a%# getting in and out
2000 f-350 4x4 extended cab, went from a flatbed work truck to what you see now, all done by me. Early 99 engine, billet low stall converter, rebuilt trans, all new uvch, new belt tensioners and idler pulley, rebuilt injectors, all new icp, idm, cps, hutch mod, k&n intake, white valve covers, wicked wheel, 5 inch exhaust, php hydra chip 15pos, 8" superlift, 20 inch black and machined rims, 2" billet spacers, 37/13.50r20 toyo open country tires, rough country dual stabilizer, 05 front end with 10k hid lights, amber led cab lights, 09 ford van bucket seats, 2010 f150 center console, b&m ratchet shifter, aero force scan gauge, b&m trans cooler used as a fuel cooler,
t-ray-4ray is offline
post #4 of 16 Old 05-25-2013, 07:13 PM
t-ray-4ray's Avatar
Quoted: 94 Post(s)
Attachment 116641this is a pic with the 4 inch lift with my 35/16/12.50 wild country mud terrains on stock lariat rims
post #5 of 16 Old 05-25-2013, 07:34 PM Thread Starter
I like the stance your truck has t-ray it looks good.
post #6 of 16 Old 05-25-2013, 07:42 PM
t-ray-4ray's Avatar
Quoted: 94 Post(s)
Thanks man plus of I go any higher on the back my exspensive adjustable hitch would be useless it's already on its lowest setting
post #7 of 16 Old 05-25-2013, 07:55 PM
897.3alltheway!'s Avatar
Quoted: 13 Post(s)
if your going with 6" get 37" tires and 4" with 35" tire , dont know wheels sizes
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #8 of 16 Old 05-26-2013, 04:46 AM
I was between the 4 and 6 inch lift for a while myself. I went with the 6 inch lift and 37 inch tires. I couldn't be happier. It is tall but not too tall and still rides like a stock truck. I know I wouldn't have been happy with a 4 inch lift.
For Sale: 2013 Lariat Ultimate CCSB 15K miles
3.55 ELD, Tinted, AMP setps, Retrax Pro, Two Spot Rigid D2 Dually's, Two Flood Rigid D2 Dually's, Fabtech 6in lift, Billstein struts, Dual Pro Comp Steering Stabilizers, 20in XD Addicts, 37x13.5x20 Toyo M/T, Line-X, Diversi-Tech 12" drop hitch, H&S Mini Maxx, 5in Flo Pro, H&S EGR delete, S&B CAI
FMKeith is offline
post #9 of 16 Old 05-26-2013, 04:50 AM Thread Starter
Yeah that's what I'm afraid of honestly that's where I am now I thought I'd be happy with a leveling kit but it's been on it almost a year and I'm not. Your truck looks real good by the way! I like the stance of it a lot.
post #10 of 16 Old 05-26-2013, 04:57 AM
Do the 6 and 37's. You will be happy you did.
FMKeith is offline
