05 F250 with 2.5" Leveling Kit. Need Shock Entenders or New Shocks? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-23-2013, 02:42 PM Thread Starter
I just picked up an 05 KR. Love the truck but sure is a rough ride. Truck has 134K on it with 2.5" Coil spacer without shock extenders on stock FX4 shocks...
Should I try shock extenders or just replace the shocks since they are probably due anyhow?
If I replace, what size should I look for in order to avoid the need for shock extenders?
I have read good and bad on Bilstiein but didn't mind them on a 1/2 ton Chevy but I am open to other brands if they ride smoother and wont break the bank...
Any tips helpful!!
TxOutlaw is offline
post #2 of 7 Old 07-15-2013, 05:15 AM
EMTspencer's Avatar
im glad you posted this, im about to do the same and was wondering these same questions. Right now im searching through old threads for answers. If i find them i will post back in here with a link for you
"Life is tough. It's even tougher if you're stupid."
-John Wayne-
Spencer
2005 F250 Lariat FX4
295/65/20 Nitto Trail Grsapplers on Stock 20s
Muffler and Cat Delete
EMTspencer is offline
post #3 of 7 Old 07-15-2013, 06:14 AM
I installed the Pro Comp 2.5" leveling kit on my truck which came with shock extenders. Very easy install without having to replace the front shocks.
99.5 F250 7.3 (Sold)
2006 F350 6.0 CC LB SRW FX4
Pro Comp 2.5 Leveling Kit
New Premium FICM from Ed
IPR GEN 2 EGR Delete w/ Up Pipe
Flo Pro 4" Turbo Back w/muffler
Blue Spring Mod
SCT Livewire ts
Ag Street Tune by Eric
NCDeerHunter is offline
post #4 of 7 Old 07-15-2013, 06:35 AM
Gapowerstroke's Avatar
I have an 06 and used the carli starter kit which came with custom valved bilstien 5100's, knew track bar and I wouldn't have done anything different. Ride quality and handling are better than stock.
06' F250 CC SR SB FX4 AT
Studs,S&B CAI, MRBP 4" exhaust 3.5" down pipe, SCT LIVEWIRE TS, Tuned by Eric (xtreme street and race), Innovative Inductive and Performance FICM Tunes, blue spring upgrade, 2.5" Carli Leveling kit, 18x9 BMF Novakane Death Metal with 35x12.50 Toyo MT's 3:73 gears.
Gapowerstroke is offline
post #5 of 7 Old 07-15-2013, 09:43 AM
EMTspencer's Avatar
How much did that run you if ya don't mind me asking?
Sent from AutoGuide.com App
-John Wayne-
Spencer
post #6 of 7 Old 07-15-2013, 10:03 AM
Kit was $890 but doesnt include rear shocks or a block. I was undecided(still am) on what to do in the rear so just a 3" block to replace the factory. Havent changed rear shocks yet and if I had it to do over I would have just stacked a 1" block on top of the factory. There are cheaper kits but they don't include the track bar and if you want your front end right then you need it so add that to a cheap kit and you might as well spring for carli quality. It rides great! Here is what I bought.The folks at 8-lug were great to deal with.Carli SuperDuty Leveling System
post #7 of 7 Old 07-16-2013, 06:31 AM
Quoted: 4 Post(s)
Feedback Score: 5 reviews
I'd get new shocks..stockers are not very good quality. You will also need Castor shims and a adj track bar to recenter the axle and get back the lost Castor.
CT Performance, Inc. is offline
