38's on 2006 F-350 - Ford Powerstroke Diesel Forum
Old 03-07-2008, 10:55 PM
38's on 2006 F-350
I have a 2006 F-350 King Ranch Crew Cab SRW. Thinking about putting a 8" Pro Comp Stage II lift on it. Will I be able to run 38x14.50x18's with out them rubbing on anything or having to trim anything? The wheels I'm looking are 18x10 with a 4.5" backspacing.
Thanks
Old 03-08-2008, 03:48 AM
they should fit. 6 inch clears 37x13.5's
Old 03-08-2008, 03:50 AM
they will fit no problem...some guys running 40's on 8 inches....good luck send us pics if you do it
Old 03-08-2008, 01:10 PM
I have 38x15.5's and they rub right on the corner of the bumper everytime I try to turn tight,Im on an 8" lift. 14.5's may work but not positive.
Old 03-08-2008, 01:33 PM
Rob Rob is offline
they will fit, you may have to trim the lower portion of the air dam to prevent rubbing, it also may rub on the leafs in extreme turns. wider offset wheels can eliminate that.
Old 03-08-2008, 01:35 PM
I don't think 06's have leafs in front.
Old 03-08-2008, 01:40 PM
Rob Rob is offline
oh thats right, they have the coil overs.. sorry, read it in a hurry! thanks Dlonno! may still have to trim the air dam though.
Old 03-08-2008, 08:29 PM
Thanks for all the input. Going to give it a shot. Thanks again
Old 03-09-2008, 08:44 AM
With trimming and the right wheel b.s you should be able to get away with a 38x14.5 tire. Also try using a tire that doesn't have big lugs so that helps with clearance as well.
Nor-Cal Nick
Old 03-11-2008, 02:53 PM
rim off set
Nor-Cal Nick
whats up can you help have a 99 f350 srw psd 6 inch lift on 35 x 12.50 procomps
18x 9 rims want to go to a wide rim looking at some 18 x 10 with a -25 or -43 what do you recommend want it to look wide but dont want to have spindle bearing problem please help some say -25 others say - 43
