Needing longer drag link sleeve - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-22-2013, 03:39 PM Thread Starter
LEARNING AS I GO
bck4more's Avatar
Anyone know where i can get a longer drag link sleeve. The one i currently have is 5" long and im needing longer. Thanks guys
1999 Ford F-250 Crew Cab Lariat 4x4 7.3L Powerstroke zf 6-speed Planet colors Amber White Pearl
banks big head wastegate, edge ez module
snow performance, 4" stright pipe,6637 FILTER MOD southbend stage 2 clutch, 05' front end upgrade
8" procomp 37" M16 Swampers 18x9 xd monsters, MOOG everything BILSTEIN SHOCKS BILSTEIN DUAL STEERING STABILIZER COOLANT FILTRATION, 203 stat 08' mirrors
bck4more is offline
post #2 of 5 Old 05-22-2013, 04:16 PM
If you are correcting for a suspension lift, a dropped pitman arm would be a better answer.
Sent from my LG-VS700 using AutoGuide.Com Free App
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #3 of 5 Old 05-22-2013, 04:32 PM Thread Starter
LEARNING AS I GO
bck4more's Avatar
Well I already have a drop pitman arm but my drag link sleeve broke and front end shop said maybe a longer sleeve would be the way to go. I'm not sure how much of a drop my pitman arm is so you guys might be right maybe that would be a better route.
Sent from AutoGuide.com App
bck4more is offline
post #4 of 5 Old 05-22-2013, 05:15 PM
A 4"-6" pitman arm should work with an 8" lift. Think about it, if you don't need a pitman arm for a 2" leveling kit, then there should be enough give in a 6" pitman arm for an 8" lift. I have some things to do right now, but I can upload a picture of my 4"-6" lift dropped arm later this evening, you may not have a deep enough arm. It's possible that it broke due to stress, you know, normal breakage.
Karls03 is offline
post #5 of 5 Old 05-22-2013, 06:21 PM
Got it!
I measured from roughly the center of the steering box nut to the drag link ball joint nut and it was 7 inches, this should give you an idea how big (or small) yours is.
Karls03 is offline
