Steering seem hard - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-18-2013, 04:48 PM Thread Starter
Silver200273L's Avatar
Steering seem hard
On my 2002 F250 4WD. I got the truck about year ago and I noticed that the steering seem hard. You might not understand what I meant hard. I will explain. When I start up the truck and put it drive and everything is fine. But if I parked in parking lot and want to turn steering wheel before I pull out since I have long bed. Well I seem can't turn my steering wheel while I'm in park. Other Super Duty I tested drove before and I was able to turn steering wheel while in park. Is my steering system bad? I would like to fix this problem since I parked in small parking lot at work and I'm getting frustrated trying get big truck out of parking lot. Thanks.
DP Tuner
Dieselsite Wicked Wheel II
5" Straight Pipe
6637 DIY Intake
Riffraff Intercooler Boots
Riffraff CCV
Harley Davidson Headlights Conversion
05-07 Grille
2.5 Leveling Kit
33" BFGoodrich All Terrain
LED tail lights
Billet Grille
Line of Fire
Silver200273L is offline
post #2 of 6 Old 05-19-2013, 09:56 AM
Gapowerstroke's Avatar
I have an 06 and was in a front end collision. After that my steering was hard especially when stopped or slowly moving. Took is to ford and they replaced the steering gear which they said has a tendency to stretch the splines (their words exactly) and the wreck likely made it worse. They replaced the gear and it steers very easy now. I can turn it with my finger even with 35x12.50's. I have seen several threads about this on different forums so it seems to be a common problem. Good luck.
06' F250 CC SR SB FX4 AT
Studs,S&B CAI, MRBP 4" exhaust 3.5" down pipe, SCT LIVEWIRE TS, Tuned by Eric (xtreme street and race), Innovative Inductive and Performance FICM Tunes, blue spring upgrade, 2.5" Carli Leveling kit, 18x9 BMF Novakane Death Metal with 35x12.50 Toyo MT's 3:73 gears.
Gapowerstroke is offline
post #3 of 6 Old 05-19-2013, 01:20 PM Thread Starter
Thanks man! Wonder how hard is to replace steering gear?
DP Tuner
5" Straight Pipe
6637 DIY Intake
Riffraff CCV
05-07 Grille
2.5 Leveling Kit
LED tail lights
Billet Grille
Line of Fire
post #4 of 6 Old 05-20-2013, 10:11 AM
Check your suspension components see if everything is tight inspect your U-joints. My steering is very sloppy and I always have to correct from left to right while driving almost constantly. My steering box is toast waiting on a new one
2004 F350 PSD
8" Icon, Loud Pipe, 58v FICM, Deleted, MudGrapplers, Edge Insight, Sct tuned by Vivian.
2011 F350 PSD
AFE , Airbags, Recon, BMF , Nitto,
20046.0 is offline
post #5 of 6 Old 05-20-2013, 10:13 AM
sprksonu's Avatar
if i was replacing the steering box i would go with redhead they are top notch
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #6 of 6 Old 05-21-2013, 04:55 PM Thread Starter
I already knew that I'm going to need 4 ball joints and all the seals. I'm leaking gear oil on driver side of axle. I plan on do the repair and also gear box.
DP Tuner
5" Straight Pipe
6637 DIY Intake
Riffraff CCV
05-07 Grille
2.5 Leveling Kit
LED tail lights
Billet Grille
Line of Fire
