Lift Decide on Lift - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-16-2013, 05:45 AM Thread Starter
Help Decide On Lift
Hello All,
I am torn between the Icon and Carli systems that are listed below. I have a 2012 F-250 Crew Cab and intend on putting 20" rims along with 35" tires on the truck. What are your opinions on the following two options?
Icon Stage 4 4.5" Lift:
Icon Vehicle Dynamics 4.5" Stage 4 Lift Syste (DR6-4563)
$6,643.51
$6,643.51
Front Coil Spacer Option: Icon Vehicle Dynamics TEI Spacer (1")
$147.00 $147.00
Coil-over Conversion: -- None --
Rear Lift Options: One Up Offroad 5" Adjustable Position Fabricated Blocks
$162.50 $162.50
Carli Coilover with full leafs
CS-FORDCOS-11-11FSP Carli Ford Coil Over 2.5 System
Vehicle Application: 11-13 F250/F350 4x4
Full Leaf Upgrade: 11-13
Upgrades: Add Stainles
usafakid09 is offline
post #2 of 6 Old 05-16-2013, 07:31 AM
I dont have experience with either of these brands but i will say each of those icon shocks are 1000 dollars
FordF250Lover is offline
post #3 of 6 Old 05-16-2013, 07:55 AM
OCVeloMan's Avatar
Quoted: 173 Post(s)
Garage
Let me know if you have any questions on the Carli system... If i were you, i would save some money and grab our Pintop 2.5 (4.5") suspension system with a full leaf pack in the rear. It costs less than either of the above you listed and rides better than the base coilover system when you add the full leafs. The only reason to run the C/O is if you want height adjustability or to run a bypass shock. If not, the independent shock/coil setup in the pintop will give you the same travel and ride quality as the valving is identical. The pintop setup is $4,220.00 (+200 for stainless) and the full replacement leaf spring replacement is $455 over the cost of the kit. That comes in under the price of the coilover with add-a-packs. Further, we recommend 37" tires with our 4.5" systems on no more than a 9" wide wheel with 5"-5.5" of backspacing.
The other good thing, if something goes wrong and you snap a shock shaft or something, you can limp it home. Break a coilover rod-end, and you're not going anywhere...
Thanks and good luck with your build.
Dan
OCVeloMan is offline
post #4 of 6 Old 05-16-2013, 08:56 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
A 4 link kit will ride better.
How do you use your truck?
4.5" and 35" will have lots of tire clearance as 37" will clear fine..2.5" may fit better for looks?
For best ride quality rear springs are best but will loose some towing capacity.
You may also want to look at a Pure Performance 4 link Chase kit.
We are a dealer for both Icon and Pure..if I can help please PM me.
CT Performance, Inc. is offline
post #5 of 6 Old 05-16-2013, 01:41 PM
layson's Avatar
Quoted: 82 Post(s)
Icon & OUO...
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #6 of 6 Old 05-16-2013, 04:57 PM
I have heard good about carli, icon, and pp. I dont think you could go wrong either way. I do not have experience with either but have heard people say the carli kit rides a bit better than icon, but idk.
Does anyone make a good rear spring below a 4in spring? How do these rear springs compare to oem springs?
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
