Deaver vs Atlas Springs??? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 05-15-2013, 09:31 AM Thread Starter
Let's Run'em
TwinTurboStroker's Avatar
Quoted: 10 Post(s)
So I was about to pull the trigger on a set of Deaver springs for the rear of my truck, to try to bring it up to par with the 4.0 coilovers and bump stops I'm running on the front.........well that was till I got the latest issue of Diesel Power and it has me wondering about Atlas Springs, as that seems to be the spring of choice of all these Dodge boys....... anyone know anything about Atlas springs vs Deavers???
-Julian
4th 6.fo
TwinTurboStroker is offline
post #2 of 14 Old 05-15-2013, 10:18 AM
Skyd Ram's Avatar
Quoted: 140 Post(s)
Dodge Trucks Xtreme - Ocotillo Wells 2012 - DTX - YouTube
The first truck in those pics is running Carli/Dealer leafs and the others are running Thuren/Atlas leafs.
Carli has been using Deaver for years and they have been very happy with them. They are a bit pricy compared to others but worth it in the long run.
Atlas builds leafs for manufacturers like Thuren and Pure Performance as well as direct to consumer.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
post #3 of 14 Old 05-15-2013, 10:23 AM Thread Starter
Let's Run'em
Quoted: 10 Post(s)
Yeah they are pretty pricey, especially compared to the Atlas......can I get a quote on the E-89's, I'm pretty sure those are the ones I need
-Julian
4th 6.fo
post #4 of 14 Old 05-15-2013, 03:15 PM
OCVeloMan's Avatar
Quoted: 173 Post(s)
Garage
As George said, Parker is the first picture and he's running our King 3.5" shocks all around with long travel leaf springs and chromoly shackle. Most of the trucks in that video are running our Deaver springs as Thuren actually refers his customers to buy our rear springs.
OCVeloMan is offline
post #5 of 14 Old 05-16-2013, 04:41 AM Thread Starter
Let's Run'em
Quoted: 10 Post(s)
Yea after a butt load of research and just realizing I should just stick with Deavers, any chance I can get a quote, I'm running Fabtech's 6" 4.0's and 37"s.....thanks
-Julian
4th 6.fo
post #6 of 14 Old 05-16-2013, 04:53 AM
Skyd Ram's Avatar
Quoted: 140 Post(s)
The only Ford 08+ leafs that Carli sells are the ones designed to work with their 4.5" kit. These are designed to level a truck running one of their kits which are usually closer to 5" while eliminating the factory block. Depending on if your Fabtech kit has sagged and/or how much rake you want these would work great and at worse case you could add a stock 2" F250 block. They run $1195 plus freight. Freight is around $150-$250 depending on where the pallet is going.
888-886-2480
Skyd Ram is offline
post #7 of 14 Old 05-21-2013, 12:17 PM Thread Starter
Let's Run'em
Quoted: 10 Post(s)
Thanks bud
-Julian
4th 6.fo
post #8 of 14 Old 05-23-2013, 03:10 PM
jetjock15's Avatar
Quoted: 113 Post(s)
I have ran them both and Deavers articulation and ride is far superior.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #9 of 14 Old 05-24-2013, 12:19 PM Thread Starter
Let's Run'em
Quoted: 10 Post(s)
So you're saying you'd run them again???
-Julian
4th 6.fo
post #10 of 14 Old 05-24-2013, 12:23 PM
jetjock15's Avatar
Quoted: 113 Post(s)
I have Deaver rear now and would not buy Atlas again.
