Lift shackles - Ford Powerstroke Diesel Forum
post #1 of 28 Old 05-10-2013, 05:04 PM Thread Starter
t-ray-4ray's Avatar
Quoted: 79 Post(s)
Lift shackles
Does anyone have 2 inch lift shackles on there leaf sprung 4x4 f 250 I would like the dimensions on them I can make my own I just need measurements
Sent from AutoGuide.com App
2000 f-350 4x4 extended cab, went from a flatbed work truck to what you see now, all done by me. Early 99 engine, billet low stall converter, rebuilt trans, all new uvch, new belt tensioners and idler pulley, rebuilt injectors, all new icp, idm, cps, hutch mod, k&n intake, white valve covers, wicked wheel, 5 inch exhaust, php hydra chip 15pos, 8" superlift, 20 inch black and machined rims, 2" billet spacers, 37/13.50r20 toyo open country tires, rough country dual stabilizer, 05 front end with 10k hid lights, amber led cab lights, 09 ford van bucket seats, 2010 f150 center console, b&m ratchet shifter, aero force scan gauge, b&m trans cooler used as a fuel cooler,
t-ray-4ray is offline
post #2 of 28 Old 05-10-2013, 06:21 PM
I have 4" and they are huge!. I imagine 2 inch ones would be 2inches shorter. I wouldny be able to get any kind of measurements till sunday though
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
post #3 of 28 Old 05-10-2013, 08:50 PM Thread Starter
t-ray-4ray's Avatar
Quoted: 79 Post(s)
I appreciate it, I might just build me some Tomorow the ones I looked at online seem to just be two pieces of flatbar with holes in them with a piece of square tubing in the center. I have all the material at my shop and I'm sure I can make them just as good if not stronger than others
post #4 of 28 Old 05-12-2013, 09:42 AM
When I had 3" front hangers, the kit called for the shackle mount to be flipped to the bottom of the frame and use the OEM shackle. Putting the sway bar mounts on the bottom of the frame works pretty good, too, in place of longer links.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #5 of 28 Old 05-12-2013, 10:53 AM
at0075's Avatar
What else is required with this setup? I have a 3.5 inch setup in the front and stock rear. It took everybit of the lift to just level it out. I have a add a leaf and 2 inch custom blocks. That's the max for me without buying to shocks. What would be necessary for me to add shackles as well for me to get too 6 inches in the front? A 3 inch shackle, and new shocks? Would the trac bar need to be extended some more? I know it's a round about way of getting a good lift on your truck but beats the hell out of buying a whole kit with new springs. And honestly they are all gonna ride like crap when it's done lol
2004 f350 6.0, 6spd, studs, 175/stock warrens, deleted, blue spring, 6.4 banjos, strait 4 in exhaust, zoo dad mod, 35s, 3.5 in lift,
at0075 is offline
post #6 of 28 Old 05-12-2013, 11:02 AM
...because front lift blocks are soooooo much safer than a proper front lift spring.
Sent from my LG-VS700 using AutoGuide.Com Free App
Karls03 is offline
post #7 of 28 Old 05-12-2013, 12:11 PM
The drawings aren't that great, but it gives you the general idea about flipping your shackle mount instead of using longer shackles.
http://www.tuffcountry.com/NewFiles/23955.pdf
Karls03 is offline
post #8 of 28 Old 05-12-2013, 12:30 PM
at0075's Avatar
How is it unsafe to have a 2 inch block in the front? I don't off road and it rarely sees 4x4 except when the boat ramp has ice on it during hunting season.
at0075 is offline
post #9 of 28 Old 05-12-2013, 12:43 PM
Well, among other things, blocks (front or rear) act as a torque arm, like a cheater bar on a wrench. Axle wrap isn't that bad on the rear because it's not a steering axle.
Have you ever seen a block get spit out? I have.
Are these an immediate danger? Maybe not. Will these issues happen without a block? No effin way.
Something else to ponder, if front blocks aren't unsafe, then why don't ANY of the lift manufacturers use them?
A 3" hanger system and Rough Country's 2.5" lift spring and NOT using nitrogen charged shocks would give a descent ride, if that's all you're after. Honestly, smooth ride and 3/4 ton truck are contradictory terms.
Karls03 is offline
post #10 of 28 Old 05-12-2013, 02:02 PM
at0075's Avatar
They don't use them because there is no money in it. It's all a fashionable market. I have a hard time believing solid steel blocks are going to split out from under my truck.
So is the 2.5 spring or springs you speak of a set or jus a add a leaf? Thats my thought on a smooth ride and these trucks however I have a 1 ton. Not sure if the front springs are different then the 3/4 ton. The add a leaf on my truck is also off of my dads old 85 Chevy 1500. He built a kit and took it all apart when he sold it. Is it for a 1 ton truck? No, but its been working fine for the last 3 years with not problems.
at0075 is offline
