Custom springs - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-10-2013, 06:22 AM Thread Starter
Custom springs
I've been researching how to lower my truck & have continuously come up empty. It's a'13 F250 Platinum 4x4. No one offers a lowering kit for this thing. I know that most people lift these trucks, but that's my style & I strive to be different. I've come to the conclusion that my best bet may be to contact a custom spring maker to manufacture shorter coils to accomplish this. I'm looking for a 2"/4" drop. Has anyone else gone this route or know of someone who has? Any suggestions for a custom spring manufacturer?
MHORTON79 is offline
post #2 of 7 Old 05-10-2013, 12:48 PM
Recently there was a single cab short bed conversion story covered. They used DJM relocators for the forward leaf spring mounts and longer shackles on the other end. I don't know if it would be a direct bolt in for your 2013, but it would be worth sending a shout to DJM for more info.
For the front, I have read suggestions of using 5.4L coil springs to lower it. I'm pretty sure a Scorpion would squash a 5.4 spring a couple of inches.
Keep in mind that if you have to lengthen your track bar for a 2" lift, then you may need a SHORTER track bar when you lower it.
Sent from my LG-VS700 using AutoGuide.Com Free App
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #3 of 7 Old 05-10-2013, 02:35 PM Thread Starter
Thanks for the info. A spring manufacturer quoted me $268 for the springs up front. Then I could mess with the leafs & blocks in the back. I'm thinking that if I go with shorter springs up that I'll need shorter shocks up front as well? Will this be the case? With removal of the leaf springs how will this effect the ride quality?
post #4 of 7 Old 05-11-2013, 01:02 PM
Along with removing the blocks, another way to lower the rear is a longer shackle. However, you will need a degree shim to correct the pinion angle when you're done.
Depending on how much you go down, you will need shorter shocks. I don't think 2 inches would hurt the shocks, but you should measure to make sure you don't bottom them out.
Removing a leaf out back would give a softer ride and greatly diminish carrying capacity. It can also cause premature sagging of the remaining springs. Removal of the blocks, a longer shackle and/or relocating the front hanger would be the best way to lower the rear. Prior to relocating either the front or rear of the leaf springs, check your pinion angle, then shim the axle mount pads to maintain that pinion angle.
Karls03 is offline
post #5 of 7 Old 05-11-2013, 01:12 PM
Naval6.0's Avatar
National spring in El Cajon, CA make custom leafs and do a damn good job
Naval6.0 is offline
post #6 of 7 Old 05-11-2013, 01:19 PM
Just out of curiosity do you have room between the front bump stop and the frame to lower the front end to height you want? Or would you have to do some sort of spindle change to get it lower.
jeephauler is offline
post #7 of 7 Old 05-13-2013, 05:29 AM Thread Starter
Thanks for the info. This will help me greatly in my pursuit. I appreciate it.
It's been relatively easy to find custom spring makers, but I've only found one company that does leaf springs. I'll definitely check these guys out. I'd rather get custom leaf springs done to keep my load capacity relatively close to factory instead of removing one or two & greatly diminishing it.
From what I've been told a 2" drop up front would put me close to the bump stops. Close enough to maybe even having to cut them down. I was wondering if I could have some custom stops made by a company like Energy Suspensions. Maybe make a shorter bump stop with some good strength to em. If I cut my factory ones I'm sure that will be effected. I'm in research mode right now. I've had the truck for about 3 weeks & the purchase was relatively unexpected. I would've done more research before my purchase if I would've known this as the route I was gonna take. I was initially going to get a F150 Platinum. That truck is easily modified. But after test driving the 250 the 150 couldn't compare.
