steering issues - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-08-2013, 04:48 PM Thread Starter
steering issues
i have a 2006 F 250 and was recently in an accident where a young girl ran a stop sign and drove into my passenger side front wheel. She pushed my front end 5 inches to the driver side. Everything on the front end has been replaced, wheel bearings, ball jts, tie rods, track bar, track bar bracket , steering box, the arms that connect the frame to the housing. All the work was done at a ford garage and I'm still having steeing issues. It's been alligned 3x in the last 400 mi. {thats how many i'v put on it since i got it back} ford says its fine. ins says if ford says its fine then they wont do anything. I took it to a different front end shop and they have improved the floating dramatically by re-adjusting everything. but its still not quite righht. i have noticed when the truck is off and the steering wheel is unlocked i have about 2 inches of play in the steering wheel. i had my wife turn the wheels while i watched the steering box and the the shaft going into the box is moving but not on the outer side. Ive had the ford shop check the new box and they say its fine, but there was no play before the accident. I dont trust them anymore. does anyone know if this is normal or does anyone know if i can adjust this.
railroadr is offline
post #2 of 6 Old 05-09-2013, 04:30 PM
Just because the box is new doesn't mean it was adjusted properly.
Remove the driver side intercooler tube, put an Allen wrench on the jam nut on the top of the steering box, loosen lock nut, turn Allen wrench until it makes contact, but don't apply torque, hold the Allen wrench and tighten jam nut.
This should remove the play in the steering wheel.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #3 of 6 Old 05-10-2013, 07:07 AM
your steering box is trashed. get a redhead gear, it will fix the issue.
SM
by
, on Flickr
2000 Excursion Limited 4x4
heated and power everything
7.3 ltr auto
f250 "V" code front and "B" code rear springs
KYB shocks
billet grill
aftermarket headlights
beans chip with;
1: stock
2: high idle
3: economy
4: tow
5: exhaust brake
6: no start
Big Boost
Ford Powerstroke severe duty air intake AIS
WWII
Sticker Monster is offline
post #4 of 6 Old 05-10-2013, 12:42 PM
SM
Being that the steering box was listed in the replacement parts, and that the insurance company won't replace what Ford says is good, I'd try adjusting it first.
Sent from my LG-VS700 using AutoGuide.Com Free App
Karls03 is offline
post #5 of 6 Old 05-13-2013, 08:03 PM
if it wasn't adjusted properly when it was remanufactured, it isn't worth wasting time with because it likely wasn't properly remanufactured. I recently installed a red head steering gear in my ex. the difference was like night and day. it drives like a brand new truck now.
SM
by
, on Flickr
7.3 ltr auto
KYB shocks
billet grill
beans chip with;
1: stock
2: high idle
3: economy
4: tow
5: exhaust brake
6: no start
Big Boost
WWII
post #6 of 6 Old 05-13-2013, 08:11 PM
ZMANN's Avatar
Quoted: 1570 Post(s)
I would totally try to adjust and I would do it from the drivers side wheel well
We Miss you Ronnie
ZMANN is offline
