clunking in front end
I have a 99 f-350 with 94000 miles on it.
When I drive under normal roadway conditions there is a clunking underneath the front of the truck, it can be felt as well as heard from both sides, passenger and driver sides. Does this sound like I need new ball joints? blown shocks? new wheel bearings? loose shackles? Thanks Sorry I can't be more descriptive |
sounds morel ike you sway bar bushings. get the moogs i had the same thing and switched them out and the noise went away. wouldn't hurt to check your ball joints while you have her jacked up though.
Yeah, I had the same thing, I just put new links and bushings in, all better.
Thanks for the info, can you recommend a source for the moog bushings? I just got the truck so I am still learning about it.
powerstrokeshop.org has what you need.
I dunno, I just got the ones from napa
