What size of lift? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 05-03-2013, 07:50 AM Thread Starter
kclough's Avatar
What size of lift?
I'm looking at putting on 35 or 33 by 12.5 what size lift or level kit is required to fit these tires. I have an 02 ccsb 4x4. Thanks
kclough is offline
post #2 of 9 Old 05-03-2013, 07:52 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
Want suspension or body? 4" suspension lift would serfice
Sent from AutoGuide.com App
2000-7.3L is offline
post #3 of 9 Old 05-03-2013, 07:57 AM Thread Starter
kclough's Avatar
Suspension I found on the internet a 3 inch leveling kit which is a spring pack for 100 bucks. I also have air bags on the rear so I can raise the rear quite abit to level the rear out
kclough is offline
post #4 of 9 Old 05-03-2013, 09:30 AM
33s will clear without a lift, depending on wheel width, 35s will need a 4" lift. Personally, a 315 on anything less than a 10 inch wheel is asking to ride on the center of the tread.
Either go all in on a complete lift or leave the entire idea alone. I could have had a bad a$$ lift on my truck with the money I spent 'doing it my way'.
Sent from my LG-VS700 using AutoGuide.Com Free App
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #5 of 9 Old 05-07-2013, 02:41 PM Thread Starter
kclough's Avatar
Ok I have received my tax return and am getting tires this weekend can I get 35s on with a 2.5 leveling kit on stock rims
kclough is offline
post #6 of 9 Old 05-07-2013, 03:11 PM
I've seen 35s on the stock wheels done before on both leaf and coiled trucks. However, you're not going to get too much air in them before they start riding on the center tread. 8 inch wheel, 12.5" tire, these things happen.
I suggest that after you mount them, run some chalk across the tread and check for how it wears off. When there is still chalk on the outsides, reduce air pressure and repeat until it all scrubs off. Don't be surprised if you're running 40 psi when you're done, that's what I run my 315s at on a 10 inch wheel.
REMEMBER the inflation on the tire says MAX PSI, not daily driver PSI.
Karls03 is offline
post #7 of 9 Old 05-07-2013, 03:17 PM Thread Starter
kclough's Avatar
Thanks I think I'm goin 35s with 2.5 leveling kit then thanks for the advice
kclough is offline
post #8 of 9 Old 05-07-2013, 03:25 PM
powerstroke_steve's Avatar
this is a 4.5 inch lift with 17" rims and 35" toyo mud terrains. just so you have an idea.
U Mad Bro???
powerstroke_steve is offline
post #9 of 9 Old 05-07-2013, 04:34 PM
Koda22's Avatar
Quoted: 5 Post(s)
I got 35s on my truck, and its just got a leveling kit..should be good to go
Koda22 is offline
