Leveling kit with towing - Ford Powerstroke Diesel Forum
post #1 of 17 Old 05-02-2013, 01:40 PM Thread Starter
Redlazer's Avatar
How does adding a leveling kit effect towing? I tow a 23ft boat and sometimes a 32ft 5th wheel camper. I like the look of a trick with a leveling kit but still need to tow allot of weight at times.
early 99 Red F-250 XL SD, 7.3L, 6-speed manual, Extended Cab, Long Bed, 4x4 Off Road, and Reflexxion Cowl Hood, Ion Alloy 183 wheels, 05 headlights with 6000k AC HID kit, and led turn signals, Ford ASI filter w/ zoodad mod and foam sleeve, TS 6 position chip, Auto Meter Z series Boost and EGT gauges, and straight pipe oem exhaust. .
CAROLINA GRAY BOY
Redlazer is offline
post #2 of 17 Old 05-02-2013, 01:41 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 270 Post(s)
put air bags on it to keep it level with a load.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #3 of 17 Old 05-03-2013, 10:13 PM
The truck sits tail high to level out under load. A leveling kit will make it nose high loaded, hence the air bag statement.
Sent from my LG-VS700 using AutoGuide.Com Free App
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #4 of 17 Old 05-04-2013, 07:03 AM
Slacker
Evil Eye's Avatar
Quoted: 190 Post(s)
Feedback Score: 4 reviews
x2 what those two guys said above. Even with air bags, a heavy 5th wheel can still cause it to squat a bit.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #5 of 17 Old 05-04-2013, 11:15 PM
blue99stroker's Avatar
Quoted: 244 Post(s)
mine had a leveling kit installed when i bought it.
but i think the previous owner put a f350 block in the rear which is like 1 inch taller than the f250 block.
this raised the back up so it is slightly raked forward.
it looks perfect when i tow.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #6 of 17 Old 05-04-2013, 11:23 PM
valhalla1's Avatar
I personally never understood this leveling fad with trucks, they are for loads and built that way, just remember to reaim (or have reaimed) your headlights as raising the nose up will put the headlight aim out causing you to blind people on low beam, and have reduced lighting (on road surface) when on high beam. just put a ride height adjustable airbag system on and it will keep the load a pre set perameters....just my $.02's
valhalla1 is offline
post #7 of 17 Old 05-05-2013, 06:44 AM
Slacker
Evil Eye's Avatar
Quoted: 190 Post(s)
I also installed the F350 blocks but mine was because it was slightly nose high. Now, it's perfect when driving around town, but when towing the 5er, it can make it squat pretty good. Air bags help, but doesn't completely eliminate my problem. I might need to bump up to 4 or 4.5" rear blocks, which will give me a slight rake when driving around town, but should eliminate the sag while towing.
My issue is slight, but it's driving my OCD insane...
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
post #8 of 17 Old 05-10-2013, 08:25 AM
Onawave's Avatar
I put a 2 inch lift on the front of my 01, knowing the rear squatted like a girl puppy with my 5th wheel loaded. I fought and searched what to do with the rear.. I was against air bags. The thought of having to put air bags made me mad. These truck should be able to handle anything with out mods to the rear..
After 2 months of searching all kinds of what to add in the rear I bought air bags.. OMG!! I LOVE THEM!!! The 5th wheel pulls a thousand times better!! I can't believe the difference. Even if I didn't add the front level kit I would put air bags on the rear. They are spendy, and not to bad to install.. and makes a world of difference.
Paul
Onawave is offline
post #9 of 17 Old 05-10-2013, 10:29 AM
Bags made that big a change in yoru feelings on them ey? I cant decide between bags or 4 inch blocks. There are bags out there for 290 for a manual inflating set, or 4 inch blocks for 160 with ubolts.
I only tow maybe 15 weekends a year so not that much, and figure the blocks are cheaper, quicker install, but if bags really make it that much better may be worth it.
2010 Ford F250 XLT ; 5" Diamond Eye DP Back ; 2" Rough Country Leveling Kit ; 18x9 XD Hoss's wrapped in 33 Mastercraft AXT's ; 4" Top Gun Customz Blocks ; SCT Livewire w/ Gearhead Custom Tunes : AFE Stage 2 CAI
madcat6183 is offline
post #10 of 17 Old 05-10-2013, 10:56 AM
Quoted: 270 Post(s)
The blocks dont do anything to help with extra weight but the bags will.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
