Dog Tracking? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-30-2013, 07:36 PM Thread Starter
Dog Tracking?
Someone I work with said my truck was "dog tracking". Now I'm guessing it's something to do with the suspension and drive line angles but where should I start looking?
Front
2 8" Icon leaf springs
2 vs icon shock
Icon track bar
Dual steering stabilizer.
Drop pitman arm
Drop track bar bracket
Rear
2 8" Icon springs
2 vs icon shock
Drive line shim kit.
One thing which could cause issue might be that I still have the stock sway bars in the rear?
2004 F350 PSD
8" Icon, Loud Pipe, 58v FICM, Deleted, MudGrapplers, Edge Insight, Sct tuned by Vivian.
2011 F350 PSD
AFE , Airbags, Recon, BMF , Nitto,
20046.0 is offline
post #2 of 4 Old 04-30-2013, 09:31 PM
1BADTON's Avatar
Never heard of it called "Dog Tracking" but dog walking yes. Most vehicles do it. some worse than others. First off check all hardware under the truck, (u bolts,leaf springs/packs and centerbolts,mounts,frame,coils,track bar,etc) The cheap/simple way to find out is a tape measure. Go under the truck and start taking measurements. Distance from the same points on the frame to the front and rear axles, then triangulate/cross measurements from opposite sides to the axles. If you are not sure or comfortable with that take it to a reputable shop for alignment and a good once over.
1BADTON
01,Lariat CCLB, 7.3L, 8" Donahoe on 37"s, John woods, ARBs, 4:88, Hansen's frt&rear, 15k Warn, HID's, DP Tunr 80econo, banks cooler, adreniline, msd dpi, optima's, autometers, more to come?
1BADTON is offline
post #3 of 4 Old 04-30-2013, 10:14 PM
go get a 4 wheel alignment. problem solved
MonsterBilly is offline
post #4 of 4 Old 05-07-2013, 06:56 PM
cumminchevy's Avatar
The front end is wider than the rear. If you get a little bit of angle on your pick up when following it will look like its "walking"
Sent from AutoGuide.com App
2012 F350 PSD Lariat FX4 CC single wheel. 5" stainless MBRP dpf back. Carli pintop w/ full deavers, long travel air bags, high mount stabilizer, Walker Evans street wheels 17x8.5s w/5.5 bs and 37x13.5 Toyo Open Country MTs
cumminchevy is offline
