What part is this? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-30-2013, 09:15 AM Thread Starter
What part is this?
Bought a lift off a guy that just took it off his truck, gave me all the parts that were took off but he didn't know what everything was. I'm dumb founded at what part this is too.
Any ideas? Carrier bearing spacers maybe? But why would there be two?
Deiboe is offline
post #2 of 7 Old 04-30-2013, 09:48 AM
ZMANN's Avatar
Quoted: 1469 Post(s)
what vehicle ?
obviously it's part of an axle see semi circle ?
mount perhaps a sway bar
We Miss you Ronnie
ZMANN is offline
post #3 of 7 Old 04-30-2013, 09:54 AM Thread Starter
Whooops, knew I forgot something.. I fail at multi tasking at work and this. 06 f250 4.5" lift. Diesel 4wd
Deiboe is offline
post #4 of 7 Old 04-30-2013, 10:00 AM
KING of BLING!
ExtremeFord4x4's Avatar
Those are rear sway bar mounts
2005 Ford Excursion 4x4 Limited(Current)
2006 F350 Crew Cab 6.0 Lifted 6",22's,SRL, Edge CTS(Totaled)
2003 F250 Crew Cab 6.0 Sonic Blue Sport 38s/20s(SOLD)
2001 F250 Crew Cab 7.3 w/ 08 Clip 37s/22x14s(SOLD)
2005 Excursion Limited 6.0 I.D. Tunes 38s/20s(SOLD)
2008 F350 Crew Cab 6.4 Job II 2.5" Leveling kit(SOLD)
2001 F250 Single Cab Short Bed Looney Tuned 6.0 Conversion Studded/EGR Delete(SOLD)
ExtremeFord4x4 is offline
post #5 of 7 Old 04-30-2013, 10:56 AM Thread Starter
Thanks for the input, that clears that up. Since every one seems to know what part this is, does any one happen to know the manufacturer or what kit these usually come in? Trying to figure out who makes this kit..
Unless this is a stock take off...
Deiboe is offline
post #6 of 7 Old 04-30-2013, 11:45 AM
KING of BLING!
No problem. It is a stock take off. Some truck had a rear sway bar and some didn't depending on the package. They bolt to the axle using u-bolts which I don't see in the pic.
post #7 of 7 Old 04-30-2013, 11:59 AM Thread Starter
Yea that's what I figured after looking around. Seems like the guy gave me extra stock take off **** that his new lift replaced. I'm guessing what I thought were AALs is really a over load spring too. a 5" block with the stock block removed + a AAL would give about 4" of rear lift.. Seems too much for a lift that is supposed to be 4.5" front.
Deiboe is offline
