04 ball joint? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 04-28-2013, 04:28 PM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
04 ball joint?
When i turn the wheel I get a loud creaking noise come from driverside I tried to hear where it was coming from it seems like it was from the upper ball joint. Any recommendations or thoughts could I just try to grease it up or is it need replaced.
04 f250 cc sb.
Egr block off, 4 inch turbo back ss magnaflow exhaust, billet turbo wheel, 05 Harley headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP, BDS Dual rear add a leaf, Firestone ride rite airbags, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
jmeaby is offline
post #2 of 15 Old 04-28-2013, 04:36 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
Time for ball joints.
dhanna6powerstroke is offline
post #3 of 15 Old 04-28-2013, 04:57 PM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
Is that common the noise it is making?
04 f250 cc sb.
jmeaby is offline
post #4 of 15 Old 04-28-2013, 04:58 PM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
The noise concerns me and I just wanna make sure I get it fixed or is this gonna be process of elimination
04 f250 cc sb.
jmeaby is offline
post #5 of 15 Old 04-28-2013, 05:03 PM
Mod Newbie
Quoted: 19 Post(s)
Jack the front end up and see if your wheel moves in and out from top to bottom.
post #6 of 15 Old 04-28-2013, 05:07 PM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
Is there a way to check the wheel bearings also?
04 f250 cc sb.
jmeaby is offline
post #7 of 15 Old 04-28-2013, 05:12 PM
Mod Newbie
Quoted: 19 Post(s)
I've never had a bearing be loose on one, they usually make noise.
post #8 of 15 Old 04-28-2013, 08:48 PM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
So as long as its riding smooth ( well for a truck) and they are quiet leave them alone
04 f250 cc sb.
jmeaby is offline
post #9 of 15 Old 04-28-2013, 08:54 PM
ZMANN's Avatar
Quoted: 1355 Post(s)
jack the tire off the ground and try to rock the tire top and bottom side to side
they are unit bearings so they are non serviceable
they usually start growling or making a noise to give you heads up
We Miss you Ronnie
ZMANN is online now
post #10 of 15 Old 04-28-2013, 10:25 PM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
thank you guys for the help tomorrow ill be checking it out and ill tuesday inspection so then ill def know haha
04 f250 cc sb.
jmeaby is offline
