14" lift in progress - Ford Powerstroke Diesel Forum
post #1 of 64 Old 04-26-2013, 06:11 PM Thread Starter
Quoted: 3 Post(s)
Changed out front Procomp 4" leaf springs for Icon 8" leaf springs. Everything went extremely smooth and had it all bolted back together within 2 hours.....Then I realized my lower actuator rod on my front leverage link system was too short and my shocks were under no load. The upper actuator rod was under a bind so I had to disconnect the rods. I let each joint out halfway and gained 1.5" but it's still not enough.
After 5 hours of working on the front we decided to call it a day. I need a longer lower rod so I'll be calling to see if any machine shops are open on the weekend. Rize is closed on the weekend so no help there.
I'm installing 9.5" PMF traction blocks in the rear tomorrow. I had plenty of time to do it today but the dang UPS man screwed me again. He ended up dropping my packages off at 7:30pm! 5 hours later than I've ever seen him come by here! I'll upload some pictures of the fine delivery work they do. I haven't received a single package from them that wasn't busted up and they kept their record going. I received 4 boxes today and EVERY SINGLE ONE had holes, dents, tears, etc. Good thing Trevor packs them so well, my silver powdercoat didn't get scraped
The last 2 pictures are of it sitting on the ground with the rear on jack stands. It's HUGE, much taller than I was expecting. I'm 6'8" and can barely touch the top of the cab!
Some more bad news... I checked my balljoints before we started and I'm starting to get some play in them. O Joy
11 F250 CCSB King Ranch
Gearhead tunes, No Limit Stage 2, No Limit Block Off, 5" exhaust, CTS
2.5" Carli Commuter, 37x12.5R20 Toyo RTs, Stock wheels
01 Ex 7.3l Limited
Swamps tunes, 6637, 4" exhaust, 6.0 trans cooler, Hellwig rear swaybar, CTS
06 headlights
bigred3297 is offline
post #2 of 64 Old 04-26-2013, 06:56 PM
897.3alltheway!'s Avatar
Quoted: 11 Post(s)
any advantage of having shock mounts like that up front? vs just straight up shock
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #3 of 64 Old 04-26-2013, 07:05 PM
wired1's Avatar
looking good! hardest part for the rear is going to be the drilling of the frame for the traction bar mount and his new style looks a lot easier then the older set up.
2013 F150 FX4 EcoBoost fully loaded with the app pkg on Icon 2.5" coilovers
06 F350 Lariat-PMF 8" on 37'sSold
09 F350 ccsb Pmf 7" on 37's Sold
01 F250 ccsb 6" on 35's with to much to list Sold
98 Cobra Vert 583 RWHP Sold
wired1 is offline
post #4 of 64 Old 04-26-2013, 07:45 PM Thread Starter
Quoted: 3 Post(s)
Honestly, it's a lot smoother on the highway than any other superduty I've owned. Not sure how the setup makes it ride like that but Rize claims it as the smoothest riding highway suspension. Anything other than cruising on highway is just a rough as stock. Potholes still suck as does rough trail roads. Seeing as its lifted and sitting on 38's I'm happy with it riding like stock. It means the kit works well sideways
01 Ex 7.3l Limited
06 headlights
post #5 of 64 Old 04-27-2013, 08:14 AM
Fall Guy's Avatar
Quoted: 7 Post(s)
Nice setup Post pics of the rear when your done.
Fall Guy is offline
post #6 of 64 Old 04-27-2013, 02:25 PM
NotStock's Avatar
She is gonna be a beast! How close did the powder coat match? Glad UPS didnt ding anything up!
Precision Metal Fab
Trevor Hall
(520)465-7971
NotStock is offline
post #7 of 64 Old 04-27-2013, 09:47 PM Thread Starter
Quoted: 3 Post(s)
Thanks Trevor! The powder coat matched perfect, I couldn't believe it. I also couldn't stop admiring your products.
01 Ex 7.3l Limited
06 headlights
post #8 of 64 Old 04-27-2013, 09:50 PM Thread Starter
Quoted: 3 Post(s)
UPS' handywork on one of the boxes. The ends torn open and all the packing peanuts were gone. Holes down the side as well
Here's the good stuff
01 Ex 7.3l Limited
06 headlights
post #9 of 64 Old 04-27-2013, 10:00 PM Thread Starter
Quoted: 3 Post(s)
I only had a couple hours to work on the truck today so I threw the blocks on. I was happy that my measurements came out right and the truck is sitting level. The absolute best thing out of this is that the truck rides AMAZING now. Replacing the front leaf springs did wonders. I didn't drive it far because I didn't want to risk binding the front but I'm excited to get a better drive when the front end is complete. Also, I can crank my tires full lock and no rubbing!
Next up is attaching the traction bars, replacing the lower rod in front, centering my steering wheel, and alignment
01 Ex 7.3l Limited
06 headlights
post #10 of 64 Old 04-29-2013, 04:43 PM
layson's Avatar
Quoted: 79 Post(s)
Spend the money and pick up a set of dynatrac's ball joints....
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
