DRW to SRW - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-22-2013, 09:48 PM Thread Starter
fordtrucks4life812's Avatar
DRW to SRW
Looking for some help on this, this may sound dumb but id like to convert my DRW to SRW in my 07 F350, for the rear do i need to change the axle and bed.... or do i just need to replace the bed? if its only the bed what do i have to do with the rear axle? I have heard on the front that i need to remove the adapters? Please help out with any info you can provide me its an idea right now but it matters how much work i gotta put into this to do it.
fordtrucks4life812 is offline
post #2 of 4 Old 04-25-2013, 01:59 PM
I believe that dually has an 8x200 bolt pattern. I know SRW trucks have 8x170. I don't know if there are any 8x200 SRW wheels out there. If not, you're going to have to change a bunch of stuff to get to SRW.
As far as the bed goes, you should be able to remove the dually flares and be done.
Sent from my LG-VS700 using AutoGuide.Com Free App
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #3 of 4 Old 04-25-2013, 05:47 PM
I believe once you take off your dually spacers/hubs your bolt pattern is 8x170, not certain though.
This makes me wonder if t can use your dually spacers so I can run 17in wheels on my dually. Ill have to look into this
You can either find a new bed or take off the dually fenders. If you remove the fenders, you'll have to take it to a shop to have some work done. I believe you will also need some type of fender flare cause they hack up the bed at the factory.
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
post #4 of 4 Old 04-25-2013, 07:53 PM
1BADTON's Avatar
fordtrucks4life812 Did mine the opposite so if you want to come down and talk or meet some where i am down in the getto of the salad bowl area salinas. Not sure of your bolt pattern but I can give you options? Brian
1BADTON
01,Lariat CCLB, 7.3L, 8" Donahoe on 37"s, John woods, ARBs, 4:88, Hansen's frt&rear, 15k Warn, HID's, DP Tunr 80econo, banks cooler, adreniline, msd dpi, optima's, autometers, more to come?
1BADTON is offline
