Rear of overload springs touching pads while driving unloaded. - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-19-2013, 06:12 AM Thread Starter
Soledad's Avatar
Garage
I've been having a rear shudder in this truck and when it's cold it doesn't shudder at all. But as soon as the truck warms up and gets some miles on it, then the shudder gets pretty bad. It only happens on take off and most of the time it's only while making a right turn. Although it can happen on a straight take off or making a left turn but it does it a lot more on right turns.
The other day I was under the truck and found that I've got about an 1/8" of slop in the rear drive shaft slip joint so I'll be greasing that up soon. And I'll be draining and refilling the rear diff with good gear oil and some friction modifier. Hopefully that will cure the problem.
Now, as I was looking around down there I noticed that the top rear of my overload springs were very clean/worn in one spot and that is just under the rubber contact pads. The front of the overload springs look rusty and like they've never touched the contact pad. There's a good many inches between the rubber pad and the top of the overload spring so it's not like they are always touching or within an inch of each other. There's definitely some good distance between them.
Soooooooo, in the worn/clean spot on the overload spring I put some white non-drying paint on it and took it for a long drive, unloaded of course. Lots of stop and go with lots of rear shudder, and nothing that would have made the suspension compress far enough to need the overload springs.
Sure enough when I got home and checked, the rear contact pads on both the driver and passenger side had white on them.
And so I was wondering if it's normal for the rear of the overload springs to contact the rubber pads under normal unloaded driving? Or do I have some really worn out springs and the shudder may be a combination of slip-joint slop and spring wrap?
Thanks!
Oh, and the suspension is completely stock except for some new Bilstein HD yellow/blue shocks and the Sulastic rubber shackles. I did the white paint test after I installed the Bilstein shocks and before installing the Sulastic rubber shackles.
2006 F-350 XLT FX4 SCLB 6.0L | TTY head bolts | stock EGR and cooler | blue spring FP mod | PHP Atlas 40 FICM tune | ScanGauge 2 & GlowShift 3-in-1 gauge (Boost/EGT/FP) | PMM coolant filter kit | Flo~Pro 4" turbo back w/muffler | stock tune
Soledad is offline
post #2 of 6 Old 04-19-2013, 09:38 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
I would check the Sulastic shackles to see if they are allowing the rear of the spring to move up higher than the stock shackles did.
Otherwise I would think that you are correct in thinking that your rear springs are worn out.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Bulletproof EGR cooler, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #3 of 6 Old 04-19-2013, 09:56 AM Thread Starter
Soledad's Avatar
Garage
Thanks GregsSD. Actually I did this "paint" test before adding the Sulastic shackles so the rear springs must really be worn out. I'm trying to wrap my head around exactly how the axle is moving/rotating to allow the overload springs to touch the pads. Is the axle rotating upwards or downwards? Or could it be the springs are just compressing that far?
I've been wanting a GoPro so I might just take the dive and buy one and mount it to the truck to see exactly what the rear suspension and axle are doing.
Soledad is offline
post #4 of 6 Old 04-19-2013, 10:04 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
A Gopro would definitely be your best bet for seeing what's going on!
When you accelerate, the pinion (front of the differential) tries to rotate upwards which would then be pushing down on the rear so this wouldn't the issue, but if you get enough shudder in the rear end maybe the axle housing is springing up and down quickly which could cause it to touch.
Just a thought!
GregsSD is offline
post #5 of 6 Old 04-19-2013, 01:07 PM
897.3alltheway!'s Avatar
Quoted: 11 Post(s)
the overload springs are just bent way up, iv seen this before
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #6 of 6 Old 04-19-2013, 07:04 PM
Ill take a look at mine tomorrow, but I think mine almost touch when parked. I think my springs are wore but to what extent I don't know. I do not think it takes much for the overloads to make contact. I am not sure how they sat when new either. Im pushing 200k and the previous owner hauled a trailer daily so im sure mine are somewhat wore
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
