2wd to 4wd swap - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-09-2008, 12:03 AM Thread Starter
2wd to 4wd swap
i have a chance to buy a 2000 f250 thats been rolled. its regualar cab long box 4wd 6 speed. what would i have to do to swap all the running gear into my 2wd extended cab long box 99 f250. i can get everything from the truck except motor and frame and it only has 14,000 on it.
jo4450 is online now
post #2 of 6 Old 02-09-2008, 12:12 AM
4everlearning's Avatar
Send a message via AIM to 4everlearning
There is alot of work involved in swapping a 2x to a 4x. you need to get the drivelines probably gonna have to have the rear lengthened or another one, crossmemebers, all the front running gear and probably the rear, springs, steering (complete), I know I am forgetting stuff here but it gives you an idea, also you will have to be able to fab some things up yourself. good luck with the project if you decide to do this. I know I enjoyed my luv when I did this, but it was way more work then I thought it would be but then I was only 17 at the time.
-Wes-
No truck anymore.
Originally Posted by dlonno View Post
Having the Looney and running the Eco is like having 2 girlfriends and choosing to bang the ugly one.
4everlearning is offline
post #3 of 6 Old 02-09-2008, 02:00 AM Thread Starter
bump......
post #4 of 6 Old 02-09-2008, 04:18 AM
lifetime member
i have one rolled right now and i am installing new body on it right now. may be an idea for you
january 2003 6.0 F-350 Lariat 4x4 cc with 08 long bed. recon cab and mirror lenses, torqueshift(reman on 9-03-09) with three disc billet convertor(500 rpm lowered stall speed),mag-hytec deep tranny pan,, 8" fabtech lift w/ 37" iroc super swampers on helos,pro comp ladder bars, custom sct x3 with tunes by eric @ innovative diesel, boost and pyro,edge insight, afe, 4" straight piped, ARP headstuds, banks intercooler & high ram intake. engine mods & maintenance by first coast diesel performance.
nsrchofpwr is offline
post #5 of 6 Old 02-10-2008, 01:14 AM Thread Starter
bump.......
post #6 of 6 Old 02-11-2008, 06:13 AM
you need the trans and t case, drive shafts, front axle, steering components and than figure out the steering geometry. crossmebers, and if its a electric t case the computer.
94_one_ton is offline
