Can a 7.3 go till the steering wheel falls off - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-13-2013, 04:25 AM Thread Starter
rosshurlow1's Avatar
I have a 02 f250 and it seems something in my steering column has shifted. I just did my ball joints and steering box two weeks ago and yesterday while jamming out the steering wheel made a pop and when I investigated it and it has a tremendous amount of play, since then it's getting a lot harder to turn and my turn signals are beginning to not turn the selfs off. It's getting dangerous to drive so replies are much appreciated.thank ya
rosshurlow1 is offline
post #2 of 4 Old 04-13-2013, 04:37 AM
duct tape & zip ties
bigcountrysg's Avatar
You need to take the plastic covers off and investigate. The plastic covers are held on by phillip head screws you can remove from the holes on the bottom plastic cover.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #3 of 4 Old 04-13-2013, 07:12 AM
my truck did the same thing, what happened with mine is there is a small bearing input shaft bearing if i remember correctly and that went but it could also be the snap ring that holds the bearing in place came lose and the spring pushed your turn signal shutter offer thing out so it won't connect. hope this helps
1992 F250 Custom
7.3L IDI 5sp manual
Ford7.3IDI is offline
post #4 of 4 Old 04-14-2013, 04:57 AM Thread Starter
I took the airbag out today thinking It would be the steering wheel nut come loose but it wasnt
