BRACKETS FOR ENDLINKS? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-11-2013, 09:14 AM Thread Starter
IV GAOT AN 03 6.0 WITH A 4" SKYJACKER LIFT, WHEN I TURN (EITHER DIRECTION) SHARPLY I HEAR THIS POP, ALMOST EVERYTIME. IT HAPPENS MORE SO WHEN ITS RAINING. ONE OF MY ENDLINKS WAS BAD, SO I INSTALLED MOOG PROBLEM SOLVERS AND NO DICE, STILL POPS, ARE THERE SUPPOSED TO BE DROP BRAKETS FOR THESE? AM I EVEN IN THE RIGHT AREA ON THIS? ITS DRIVING ME NUTS.
terry6.0 is offline
post #2 of 7 Old 04-11-2013, 01:37 PM
Another thing to check if it does it while you are turning would be your track bar. It holds the axle side to side and is under a lot of pressure when turning. We have seen a lot of times where a bolt backs off in either the bar or bracket and allows some shifting under load that will cause a pop like you are describing.
Hope this helps
Derek
Supporting Vendor
Now Under New Ownership!
We Pride Ourselves on Customer Service and Customer Satisfaction.
Give us a call at (865) 681-3008
Also #topguncustomz on Instagram!
Top Gun Customz is offline
post #3 of 7 Old 04-11-2013, 03:06 PM
shawnb99's Avatar
i would look at the track bar first, then move on to the ball joints....more than likely...with the added resistance of the tire size your ball joints are done.
04 F-250 CCSB 4X4 6.0L Auto, tweaked by GEARHEAD
follow link to truck for sale
shawnb99 is offline
post #4 of 7 Old 04-11-2013, 05:35 PM Thread Starter
ill check on the track bar, if i recall correctly, last time i had her on the lift the ball joint were ok, but both my hubs were just completely shot, so $600 later i got new hubs from ford. put new endlinks on and put a bilstein stabilizer on. just an fyi im running 325/60/20's
terry6.0 is offline
post #5 of 7 Old 04-12-2013, 06:55 PM
I had that popping in my track bar, the bolt in the drop bracket was loose. My buddy got under the truck while I cycled the steering from lock to lock to find it.
I also found that if you hang your sway bar mounts from the BOTTOM of the frame it acts like a drop bracket.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #6 of 7 Old 04-14-2013, 03:43 PM Thread Starter
by drilling new holes? pics?
terry6.0 is offline
post #7 of 7 Old 04-15-2013, 07:11 AM
Get under the truck, find the upper sway bar mounts and it will all make sense. Unbolt, flip, reinstall hardware.
That's the same way the 3" shackle lift worked that I used to have.
Sent from my LG-VS700 using AutoGuide.Com Free App
Karls03 is offline
