Help with 4" to 6" lift - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-10-2013, 05:35 PM Thread Starter
Need a little help here guys. I bought my truck with the lift and the guy said it was a 6" Bug it looks more like a 4- 41/2". I am running 35's but to me they look to small Day my lift is a 4" can I just buy coils for a 6" lift and swap them out, or am I going to need other replacement parts as far as the front end goes? And can I run 37's on 20x12 with a 6 inch lift
Here's a pic of my 6.0
Thanks in advance
jakejmnz is offline
post #2 of 2 Old 04-11-2013, 07:33 AM
How much block do you have in the rear? Does it have the OEM springs? Pro-Comp (for example) uses a 6 inch lift spring and the factory block to achieve their 6 inch lift. A 6" lift can also have an add-a-leaf and an ADDITIONAL 4" block.
Should you need to go up in the front, are there 2 holes in your track bar drop bracket? The upper on mine is for 4" and the lower is for 6". If not, then you're going to need either an adjustable track bar or a different drop bracket. Most pitman arms are for 4-6 inch lifts.
Finally, once you get your lift figured out, your tire/wheel should be fine.
Sent from my LG-VS700 using AutoGuide.Com Free App
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
