Body Lifts for diesels? - Ford Powerstroke Diesel Forum
post #1 of 23 Old 02-05-2008, 12:03 PM Thread Starter
a truck
Matt P's Avatar
Ive been looking around on a bunch of sites cause I was thinking of adding a two inch body lift to my truck this summer but every time I find a body lift kit for my type of truck it always says it wont work with trucks equipped with diesel engines. So I was wondering if anyone knew of a body lift kit that would work with a 94-97 diesel f250.
Thanks
03 king ranch w/ a cummins
Matt P is offline
post #2 of 23 Old 02-05-2008, 12:26 PM
Lonno's Avatar
Can't do it unless you rework the intercooler. Custom job and not cheap.
1970 F250 Crew Cab rebuilt/restored w/Cummin s 4bt
8v, M5R2 Tranny, VE pump, DennyT stage 2 pin, M&H Dynamic Timing, 3200k gov spring, Hx30/Hx35 Twins, 40hp styx, smoke screw screwed, star wheel cranked, Hydroboosted
91 Gillig Phantom, Converted transit bus, 6v92 Detroit Diesel
6500 Watt Diesel Generator on board
All Diesel
All Day
Lonno is offline
post #3 of 23 Old 02-05-2008, 12:33 PM Thread Starter
a truck
Matt P's Avatar
I dont have an intercooler though
Matt P is offline
post #4 of 23 Old 02-05-2008, 02:51 PM
Bamfster's Avatar
Send a message via AIM to Bamfster
Supposedly you can use one for the gas trucks, you just have to "clearance" the firewall around the exhaust manifolds. I saw this on a post on the diesel garage.
Bamfster is offline
post #5 of 23 Old 02-05-2008, 03:02 PM
BigRed's Avatar
I have helped install one on a 99 Powerstroke and it was for a gasoline powered truck. There was no intercooler mods needed either!!
Waylon
2006 F-250 C/C LB FX4
SCT tuned by everyone!
ARP Studs
Elite EGR Delete
5" MBRP w/ 6" Tip
AirRaid Intake
AccuFab elbow
ZooDad
03 Turbo
6" Rize w/ 37/13.50R22 Toyo M/T's
22x12 Rockstars
AutoMeter Ultra-Lite EGT, Trans, Boost, and Air pressure gauges
Train Horns on ViAir 450C
Avic-D3 w/ 4-10's
BigRed is offline
post #6 of 23 Old 02-05-2008, 04:58 PM
International Threat
Marty's Avatar
Do a suspension lift... not a body lift. Honestly, body lifts =
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
post #7 of 23 Old 02-05-2008, 05:06 PM
craig long's Avatar
what does the steering dampener do for me. i have a 4" lift and oversized tires. after reading my signature do i need any added suspension with the 4" in place. i am set up for hauling and tow
late 99 f250 7.3L 265k
4" lift, dual front shocks, adjustable air bags added to rear.
new calipers, brakes and rotors all around
isspro guages
rebuilt tranny with heavy clutches and shift kit. billet cowan converter.
finned front and rear diff. covers.
rhino liner bottom strips
cattle front bumper with 2" receiver, black steel rear bumper. 315/75/16 AT
diy intake
4" straight pipe
wastegate delete
ccv mod
foil delete
zoodad mod
craig long is offline
post #8 of 23 Old 02-05-2008, 08:57 PM
NOVAJOE105's Avatar
The reason there are no body lifts for the diesels has to do with the fan shroud and fan. I bought a Trailmaster(I think) for mine and they told me that I would have to do a lot of work with the fan and shroud. I haven't gotten around to doin mine yet though so I can't be 100% sure on that.
[/SIZE]
1995 F-250 4X4
7.3 DIT E4OD
4.10:1 Gears with posi rear
Shimmed FPR
ITP HPX oil crossover line
Cat and mufler delete
LT285/75R16 BFG A/T KO
RECON Line of fire with ice
178RWHP 349RWTQ....JUST THE BEGINNING
IN THE WORKS:
6" Mitre cut stacks
DP F5
EGT, Trans, Boost gauges
Electric fuel system
Other toy
1990 Chevy with a carbureted 454...kinda quick...lolSOLD!!
NOVAJOE105 is offline
post #9 of 23 Old 02-05-2008, 10:51 PM Thread Starter
a truck
Matt P's Avatar
I already have a suspension lift on mine I was just considering adding a body lift instead of upgrading to a 4 inch suspension from the 2.5 inch I already have but if its gonna be a lot of work with the fan and shroud like you say I might just hold off and upgrade to the 4 inch suspension
Matt P is offline
post #10 of 23 Old 02-06-2008, 07:40 AM
-diesel-'s Avatar
Diesels need all the cooling they can get. When you do a body lift it moves the radiator up and and away from the fan. Gas engines have some issue with cooling after the fact , Diesels are even worse.
Don't do it, you will hate it and they don't look that good anyway.
I agree Bodylifts==
2KRCSB2WD73335750
-diesel- is offline
