Rear Rumble - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-05-2008, 09:08 AM Thread Starter
Rear Rumble
I drive a '04 F-350 longbed and recently have been experiencing a rumble in the 25 to 35 mph range in the rear. I've checked most bolts (I think ) and pulled my bed liner out to check for a rock or something rattling around and have not found a solution. From what I can tell it is on the driver side and behind the cab. Any thoughts?
Hilmo08 is offline
post #2 of 6 Old 02-05-2008, 09:37 AM
just a noise or is it accompanied by a vibration too?
later,
Marine
USMC 2002-Present
2002, 7.3, CC, LB, 4x4, Pro Comp 6.5inch (really 7.25inch), Super Swamper TSL 36x12.50x16.5, centerline wheels, mud, Cobra CB, 10ft whip, mud, straight pipe dumped in front of rear tire, 10K mod, zoodad, mud, herculined custom front bumper and lined bed, etc.
marinepowerstroke is offline
post #3 of 6 Old 02-05-2008, 09:13 PM Thread Starter
oops thought I mentioned that...yea you can feel a vibration accompanying the noise.....
Hilmo08 is offline
post #4 of 6 Old 02-05-2008, 09:58 PM
GreenF350's Avatar
Hmmm...You gotta love these guessing games for a noise that you can't hear or a vibration you can't feel. Just throwing this out there, but I would start by looking at U-joints. It's quick and easy to check and somewhat common. While you are there check the carrier bearing on the "center" of the driveshaft (I think you have one). Then I think I would start checking wheel bearings. Good luck!
-Aaron
2000 Ext. Cab F350 SRW, 6" Skyjacker lift on front/8" BDS Springs on rear w/NO blocks, 37x13.50 Nitto Mud Grappler's, Aftermarket Front Bumper
-Always More Stuff Coming!
GreenF350 is offline
post #5 of 6 Old 02-05-2008, 10:30 PM
COLLEGE KID
lifewitlooie's Avatar
Send a message via AIM to lifewitlooie
Check the vibration dampener on the drive shaft. Its a circle thing on the drive shaft closer to the pumpkin. see if that is loose
Class of Aug 17, CFD
lifewitlooie is offline
post #6 of 6 Old 02-06-2008, 12:52 AM
yeah i get a vib/rumble at 40-43 mph, due to the carrier bearing. (center loop around the two piece driveshafts on long beds). i'm trying to put mine off till tax returns to change. (and my powersteering gearbox is bad again, imagine that.)
later,
Marine
USMC 2002-Present
