Front end bounces while turning. only in 4x4 - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-03-2013, 12:31 PM Thread Starter
TheMudWagon's Avatar
Question Front end bounces while turning. only in 4x4
Hello everybody, new to the forum. I'll start by describing my truck, It's a 2005 F250 Superduty Crewcab short box. 6.0,Torqueshift 4x4. Truck has a 6" Procomp lift and 37x13.50's.
Okay, now to my problem. I know that when i turn the wheel to full lock and the truck is on an incline my tires rub (no big surprise there). when just cruising in 2wd on flat ground I have no problems. I can turn my wheels to full lock with no wobble, no rubbing. There is a popping noise that happens occasionally (I'm sure it probably needs tie rods and sway bar bushings). When I have my truck in 4wd, however, anytime the wheel is turned the entire front end bounces and wobbles. Even at low speed, when i start to turn the wheel i can feel it shimmy the whole truck back and forth. If i'm moving at any decent speed (powering through a mudhole) it wobbles, bounces, and makes a terrible squeaking noise like it's trying to pull the entire front end apart (Very similar to the infamous "Death Wobble", except it happens only if the wheels are turned and is directly related to speed). I've crawled under the truck and everything is nice and tight. Has anyone experienced something similar to this? Any help would be greatly appreciated. I know this is probably a terrible description of what's happening so I'm including links to some youtube videos so you guys can see exactly what's happening;
Powerstroke playing in the mud - YouTube
Stuck Powerstroke - YouTube
2005 F250 Super Duty Crew-Cab SB 4x4.
EGR Delete, head studs, Custom Tuned by Innovative Diesel Performance via SCT X3
5" Turbo-back MBRP TD series exhaust. 6" ProComp suspension lift
37x13.50" Toyo Open Countrys, Recon LED 1400lumen floods
TheMudWagon is offline
post #2 of 7 Old 04-05-2013, 10:25 AM
I couldn't see much, phone screen too small, but it sounds pretty normal. Turning in 4 wheel can kick the steering wheel, the more traction and power, the more it kicks. Put that dude into 4HI and try turning in a parking lot, it will rip the wheel out of your hand.
The second thing is that 05 and up hop the front axle pretty easily under load. I watched one chatter so hard in a truck pull that I thought something was coming off.
I wouldn't sweat it. Be careful how you turn out wheelin, but don't lose any sleep over it.
Sent from my LG-VS700 using AutoGuide.Com Free App
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #3 of 7 Old 04-05-2013, 10:45 AM
my0460's Avatar
the squeaking noise could be the wheel u joints. All the mud and dirt Will shorten the life of them for sure.
04,cc,sb,4x4.
egr. delete
sctx3
over mirror gauges.
mbrp 4" no cat,no muffler.
my0460 is offline
post #4 of 7 Old 04-05-2013, 10:57 AM
Was that squeaking or turbo fart? I couldn't tell on my phone.
Karls03 is offline
post #5 of 7 Old 04-07-2013, 02:07 AM
Mannysouza's Avatar
Quoted: 124 Post(s)
Umm FYI,
You should NEVER drive your truck in 4wd on dry pavement. If you do don't turn or you run the risk of breaking your transfer case chain or even worse break your transfer case housing.
Also most American made trucks differentials have a difference in gear ratio between front and rear .01 or .02 which can cause stress even in a straight line but a lot less than turning your truck on dry pavement in 4wd.
Mannysouza is offline
post #6 of 7 Old 04-07-2013, 04:04 AM
leojr's Avatar
Quoted: 4 Post(s)
Do you have some sort of locker in the front diff?
Denton, TX
I envy those that know exactly which modification to make and in the most logical of sequences. But not enough to trade for my meanderings and misfires.
1996 F250 crew cab/short bed, 4x4, auto PSD, 6637 air filter, interior grab handles, stainless window vents, remote door locks work with engine running mod.
leojr is offline
post #7 of 7 Old 04-07-2013, 08:51 AM
A locker or limited slip differential will make this situation worse. Turning with a limited slip or locked front end is challenging.
Turning while idling in a p-lot wasn't meant as recommendation for daily driving. Although boosted 4HI launches at the drag strip makes for killer 60 foot times.
Karls03 is offline
