leveling with shackles? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-02-2013, 04:44 PM Thread Starter
alright so i can get a good deal on some shackles, my buddys dad is a fabricator and can make me up a set if i give him money for supplies (including a 6 pack) so figuring about 20-30 for the set. are shackles a good way to go? or should i buy blocks or add a leafs? minus shocks would i need a new track bar for 2" of lift? thanks guys!
2002 F250
Leveled on 35s
[SIGPIC][/SIGPIC]
Cduff is offline
post #2 of 6 Old 04-05-2013, 11:34 AM
If you do this, I strongly recommend matching front hangers otherwise you will induce excessive positive caster. Excessive positive caster won't hurt tire wear, but it will make turning harder.
I did a 2" add-a-leaf and didn't need to change anything else. Although I wouldn't do it again, the add-a-leaf dug into the lower leaf spring.
Sent from my LG-VS700 using AutoGuide.Com Free App
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #3 of 6 Old 04-06-2013, 10:51 PM Thread Starter
what about blocks in the front? havent seen them around many places for front leaf springs but i know its an option to put spacers on front coil springs. maybe theres a reason for that.
2002 F250
Leveled on 35s
[SIGPIC][/SIGPIC]
Cduff is offline
post #4 of 6 Old 04-06-2013, 11:53 PM
I do not think it is safe or legal to run blocks in the front. However you can run mini spring packs in the front which are similar to blocks. You could do a spring hanger kit as well.
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
post #5 of 6 Old 04-07-2013, 05:52 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
i would pick up an old set of leaf springs frome somehwere and make your own mini pack. some cheaper mini packs are not made of spring steel and can cause stress on them and crack and break. if u make them with spring steel (old leaf springs) they can take the abuse, flex and return many times.
any way take an old set of leafs someone has laying around, get longer u-bolts. cut down the leafs into a mini pack and re-pin the pack and install. do not go larger then 2.5'' thick. dont know the reason but appariently it is unsafe over 2.5''???
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #6 of 6 Old 04-08-2013, 12:37 PM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Have you measured to see what height you need?
Best ride quality will always be from using a V code factory spring. You can get a hanger lift in 2,3" which will enhance the ride quality by giving additional travel.
If you want new springs and 2" and the best ride quality get X code springs will ride better than any lift spring.
As always a 2" lift needs longer shocks and requires a adj track bar or a correctly made drop bracket to correct the axle that has now shifted 1/2-3/4" per 2" of lift. Its geometry.. a science. The axle shifting will side load your spring bushings which will cause premature failure and doglegging.
2" hangers..
3" hangers..
2" mini spring packs..
X code springs..
adj track bar Billet Aluminum..
Bilsteins set of 4ea..
Rear blocks..TBD
Shipping TBD.
If I can help please PM.
CT Performance, Inc. is offline
