99-04 front u-bolt size???? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-31-2013, 06:43 PM Thread Starter
CoalRollinRoosterCruiser's Avatar
Swapping out the springs on the front of my truck, and i'm trying to find new u-bolts to use. Truck currently has a 4" pro comp lift on it, and i'm removing it and going back down to just a leveling kit.
Truck is a late 99. springs have an add-a-leaf so i believe i need 10" or 10.5" long u-bolts, somewhere there about. That's the best meaurement i can get off the one's that are currently on it.
Are the late 99-04 frot u-bolts considered "square" u-bolts, or the "large radius" u-bolts?
And what size are they?
I think the lift has been on approx. 25k-30k miles. Can i just re-use the u-bolts that are on it?
Jonathon or John Although technically i have a list of nicknames the length of I-95, so call me what ya like
Current Truck--1999.5 F350 ext cab short bed SRW Lariat 4x4 ZF-6. 4" lift, 35's, exhaust, intake, chip, and more.
CoalRollinRoosterCruiser is offline
post #2 of 9 Old 04-01-2013, 05:05 AM Thread Starter
Morning bump
Sent from AutoGuide.com App
post #3 of 9 Old 04-01-2013, 06:04 AM
rdaffin's Avatar
You can reuse the bolts if there is enough thread left on them. They don't wear out so it will not be a problem.
2004 CCSB 4x4, blue spring, SCT , 4" exhaust, Gearhead tunes, egr delete, ELC-1, Coolant filter, ARP Studs, CCV Mod, 6" lift, 35" Toyo A/T II.
rdaffin is offline
post #4 of 9 Old 04-01-2013, 07:22 AM Thread Starter
I thought since they were torque to yield they stretch?
Or is that just the rears?
post #5 of 9 Old 04-01-2013, 07:24 AM
rdaffin's Avatar
Fronts torque to 110 ftlbs.
rdaffin is offline
post #6 of 9 Old 04-01-2013, 07:26 AM
rdaffin's Avatar
Not TTY. My rear block kit came with new ubolts and they were not TTY either.
rdaffin is offline
post #7 of 9 Old 04-01-2013, 07:45 AM Thread Starter
Well heck, didn't realize that. Thought I'd read they were TTY.
Why do people say not to reuse u-bolts then?
post #8 of 9 Old 04-01-2013, 08:15 AM
rdaffin's Avatar
Maybe from a corrosion or damage standpoint! Not really sure.
rdaffin is offline
post #9 of 9 Old 04-01-2013, 03:42 PM Thread Starter
Hmmmm, alrighty
