Carli questions..... - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 57 Old 03-30-2013, 08:26 AM Thread Starter
scummins's Avatar
I have been really thinking hard this past week about which lift I want. I'm pretty dead set on a Carli 4.5" system. Probably the backcountry or performance. I use my truck alot for work, play and travel. So I think the height and ride performance will be right on. So here's my questions:
-Is the ride quality of Carli really that much better that it's worth double the price of most other kits? From what I've read, I'm thinking so, but maybe some others have used other kits that ride really good that are cheaper?
-Seems like everyone is using 37's instead of 35's? Is there a reason for that? I think I'd rather use the 35's just for fuel mileage and I figured 35's would balance out better for a smoother ride?
-If I use 35's I assume I can use a 10" wide wheel instead of 9" with no rub issues? I want to use 20x10's and 35" tires. Any suggestions on B.S.?
-Best riding tire that can still get wet traction? Trail grapplers?
THanks so much. Really pumped on this.
11 Lariat
6" lift, 37's, Moto Metals, H&S, SPE, JL SPL2K
scummins is offline
post #2 of 57 Old 03-30-2013, 09:29 AM
I cannot help because I have an 03, but I am curious what others say.
I do know Carli puts more into their systems along with research, testing, etc compared to the cheaper systems out there. Carli also custom valves the shocks used specifically for our trucks. Other companies just use standard parts that are more universal.
Icon is another good option, but I think you will find their products priced similarly to Carli.
I'm sure you will also get people saying you get what you pay for, etc. I have been thinking about a set of their leafs and maybe some shocks for my truck. Currently exploring my options. Best of luck, I'm sure you will be very happy with a carli kit
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
post #3 of 57 Old 03-30-2013, 12:49 PM
BIG Laing's Avatar
Carli is worth every penny. Icon has a $5000 4.5" lift too.
On wheels you just need to keep less backspace then the stock 8" wide +40 offset wheels.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #4 of 57 Old 03-30-2013, 03:13 PM
I think that Carli is well worth the money and piece of mind. In this era of manufactures making crap Carli is a breath of fresh air. During the last couple of decades i have had Pro-Comp, Fab-Tech, Sky Jacker, Rough Country and a few more that i have thankfully forgotten, some of the above mentioned i have broken hard parts and almost all rode bad to fair.
I have the starter system and on the street the ride is about 25% better and off road i would say it`s about twice as good compared to stock, i can hardly wait to upgrade to the Carli King shocks to make it even better.
I just mounted my 37" Toyo MT`s last week and these have improved the ride even more.
RH67 is offline
post #5 of 57 Old 03-31-2013, 07:31 AM
goosegodz's Avatar
My truck is on the lift as I type this... I went with the Carli Pintop 4.5 with full rear springs... I'm not sure when your planning on doing this but I can surely let you know how it is late next week when I can put a few miles on it....
2013 F250 6.7 ccsb,Carli Pintop 4.5, FUEL Offroad Octane Rims, Toyo MT's 37, Smittybilt light Bar, Rigid D2's, Rigid 20" LED
goosegodz is offline
post #6 of 57 Old 04-01-2013, 12:39 PM
Skyd Ram's Avatar
Quoted: 131 Post(s)
Yes- It is hard to make a comarison of the 4.5" Carli kits to others as they use alot of items that others don't like brakelines and mini packs. The key to a great ride and improved performance is spring rates, shock valving, and wheel/tire combo. Carli has these nailed.
35's actually look a bit small with 4.5" of lift on these newer trucks plus the bigger tires ride better due to more sidewall and increased air volume.
If you stuck with 35's you could run 10" wide wheels with a backspace around 5". Keep in mind that 35's on 20's aren't going to ride nearly as good as 37's on 17's or 18's.
The seem to be pretty good in the rain although I have found that the 35x12.5x20 Trail Grappler is one of the stiffest tires on the market. They also tend to develop a left pull that can be a PITA to correct. I would personally suggest either Toyo M/T's or the new Toyo ATII's.
I answered your questions above in red.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
post #7 of 57 Old 04-01-2013, 05:25 PM
Why does carli not make much for the 99-04's? Too bad they do not make front leafs for us or possibly a bolt on coilover kit. I guess most people get the newer axles for the older trucks. That's a bit harder when you own a dually, I think. Plus the costs involed for the conversion
INFRNL is offline
post #8 of 57 Old 04-01-2013, 09:57 PM
Carli Suspension is big into the Dodge HD truks, they've been using a coil sprung front end since the 90's. When Ford did away with front leafs and went to coil springs, Carli had already had a lot of RnD with this type of suspension, so it was natural to start with the 05' and up SD for suspension development. I've heard they have helped out some leaf-sprung guys, give them a call.
See you in the Dirt!
76hauler is offline
post #9 of 57 Old 04-02-2013, 11:12 AM
Skyd Ram's Avatar
Quoted: 131 Post(s)
They don't advertise it but they do have a system that uses Deavers front and rear with King 2.5's all around. The leafs and shocks are special order so the lead time is around 6-8 weeks. Give Dan at Carli a shout and he should have more info.
888-886-2480
Skyd Ram is offline
post #10 of 57 Old 04-02-2013, 11:23 AM
Clomax's Avatar
Quoted: 6 Post(s)
Okay Fellas, I plan on buying a Carli Lift, but have a few questions on the site.
Why, if the add a packs are the same, why the following:
#1 2.5 Leveling Systems
Pintop - 2.5" rear
Commuter - 1.5" rear
Starter - 2.5" rear
Why the difference if the add a pack is used on all?
#2 4.5" Lift Systems
Rear is only 2.5" on all systems.
Is the only difference from the 2.5" systems the amount of lift on the front end as well as the front end components?
#3 So all systems are 2.5" of rear lift across the board (Except for the commuter - unless this is a typo).
15 CCSB R-Red: 4.5" Pintop Carli w/LT Airbags 18x9 Centerline Bigfoot 5.25bs +6mm offset 37x13.50 Toyo MT Iron Cross HD Step
Clomax is offline
