Towing with a lift - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-29-2013, 03:49 PM Thread Starter
Towing with a lift
Hello, I recently bought 2003 f250 SD xlt 4x4 super cab 7.3l to pull my 27 ft camper that has a dry weight of 6500 lbs. I would like to put a 4 inch lift with 35 in tires on it. Would this be ok or would it cause more problems than its worth. Thanks
hllbly66 is offline
post #2 of 2 Old 03-29-2013, 04:04 PM
layson's Avatar
Quoted: 82 Post(s)
That is a height where everything still seems to be happy. I would go with an icon 4" lift kit and maybe even look into some One Up Offroad traction bars. Be good to go!
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
