Limited slip??? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-28-2013, 06:53 PM Thread Starter
Silverbullet 6.0's Avatar
Limited slip???
How can I tell if my 03 f-350 4x4 is limited slip or not?? And also what's the difference in limited slip and positrack
Silverbullet 6.0 is offline
post #2 of 3 Old 03-28-2013, 07:05 PM
There should be a metal tag on the hogs head and I think it will say "LS" along with some numbers.
8" Skyjacker lift
2" wheel spacers
22" American Racing rims
40x15.5x22 M16's
DIY intake
Zoodad Mod
4" strait exaust
Glowshift gauges
DIY Boost Fooler
Unplugged wastegate
TS 6 position chip
dr8082 is offline
post #3 of 3 Old 03-29-2013, 09:09 AM
First Post - Rear Diff Identification
Post #4 has the information that you want.
There is no difference between limited slip and positrack, both refer to a clutch type differential that sends power to both wheels under load. This is true for ALL cars and trucks. Trac-Lock, Sure Grip, etc are all mfr names for the same thing.
The tag is on the rear differential cover, but there is no S, it will either be "3 73" or "3L73" (provided you have 3.73 gears of course). If you can't make that tag out, the second tag should say something about using a specific fluid, the clutches in a Trac-Lock will burn up if friction modifier isn't used.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
