Front End Making Noise
I haven't pulled the tire off yet cuz it's really wet outside, so I figured I'd see what y'all thought first. The other day pullin in the driveway, I was at full-lock to the left and hit the brakes. Had a really nice grinding noise as I came to a stop. I can feel something up front popping when I turn sometimes. It only pops when changing directions and only pops once. I also noticed that it is starting to pull to the left a bit when I hit the brakes...which it wasn't doing before.
Any ideas? Does it sound like a hub bearing? |
It could easily be the hub bearing with the grinding noise. You don't need to pull off the tire to diagnose the problem, you do need to jack up that side of the truck and then take your hands one on top and one on the bottom and shake the tire up and down. You will probably need to have someone do this with you checking suspension parts and seeing wich one moves. Minimal play is likely but you need to keep and eye on the hub itself and see if it moves if it does it needs replaced.
When your driving and it is pulling left get out and check the wheel and it will probably be extremely hot. Mine did this and I burnt my hand touching the wheel. Which means the hub-bearing isn't spinning properly and has the brakes dragging. Think back a couple of days did you notice a slight squeel from the drivers side when you turned the wheel.
Every now and then I get a high pitched squeel at one intersection I drive through. The road is going down hill, but when I turn to the left to get off the road, it switches to uphill and if I hit it too fast and turn I get the squeel. If I'm on the brakes through the turn it will usually squeel, if I'm not on the brakes, it won't usually squeel. |
![]() 2: You shouldn't be on the brakes through a turn 3: Wheel bearings/hubs.....for almost sure. |
2: Try not too anyway, but in Cali, sometimes you have to...when people are on your *** sometimes you just don't have a choice. 3: Kinda what I'm thinking. I am going to get the front end up in the air and take the wheels off so i can play with them a little more and see if they have any play. |
