Carli Pintop Install Question?? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 03-27-2013, 05:24 PM Thread Starter
goosegodz's Avatar
In the process of having my pintop 4.5 installed on my 2013 f250 and wondered what other's have done for the ABS line that runs down the radius arms and also where the extened brake lines attach to?. I thought from the system photo that it came with another bracket but mine did not(unless I misunderstood what the tech was saying).. Is it suppose to come with another bracket? Ill attach a pic or 2
2013 F250 6.7 ccsb,Carli Pintop 4.5, FUEL Offroad Octane Rims, Toyo MT's 37, Smittybilt light Bar, Rigid D2's, Rigid 20" LED
goosegodz is offline
post #2 of 12 Old 03-27-2013, 05:39 PM
The ABS line also connects at the frame, disconnect at that point, lower it so you can now connect to the radius arm. Where you made the disconnection from the frame you can hold it with a zip tie. Your brake lines look ok, what you need is the clip off the old brake lines.
RH67 is offline
post #3 of 12 Old 03-27-2013, 06:04 PM
FYI when i installed my 37`s i had to move the front bumper forward 1/2 inch. I bought bolts that were 1/2 inch longer and nuts larger in dia. to fit over the bolts and 1/2 thick to space between the bumper and frame. My rims are -6.
RH67 is offline
post #4 of 12 Old 03-27-2013, 06:13 PM Thread Starter
goosegodz's Avatar
Thanks for that info! Would they have rubbed or was the clearance just not enough for your liking?
post #5 of 12 Old 03-27-2013, 06:36 PM
They did rub the bracket on each end of the fender at full lock, i also took 1/4 in. off each bracket.
RH67 is offline
post #6 of 12 Old 03-27-2013, 06:59 PM Thread Starter
goosegodz's Avatar
I'll have to check it out once it hits the ground.. Looks like its going to be in the shop till after the long weekend.. Wrong bushings were installed in the front shocks and they have to be expedited from Carli...Sh!t happens sometimes i guess
Thanks again RH67
post #7 of 12 Old 03-28-2013, 09:53 AM
OCVeloMan's Avatar
Quoted: 151 Post(s)
Garage
Exactly. We pull the ABS line retainer from the fender well and drill a hole a few inches lower then zip tie it. Sage just lets his hang! As for the extended brake lines, they're designed to allow full droop of the 4.5" system without relocating the factory junction! I would recommend re-fitting the junction back to the factory location as that was how we designed the system. As for the misalignment spacers, I apologize. King has done this one a few occasions but we sent them out yesterday and expedited them!
OCVeloMan is offline
post #8 of 12 Old 03-28-2013, 10:58 AM Thread Starter
goosegodz's Avatar
Thanks Dan and RH67... I passed along the info..
No need to apologize Dan... Sometimes stuff happens thats out of your/our control.. Worst part about the whole process is that now i have to rock out in a FOCUS SE loaner car till next wednesday.....lol
Todd
post #9 of 12 Old 03-28-2013, 02:46 PM
Skyd Ram's Avatar
Quoted: 114 Post(s)
Todd
Todd,
Your truck already looks badass just sitting on the lift!
Sorry about the parts mixup on Kings end.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
post #10 of 12 Old 03-28-2013, 04:03 PM Thread Starter
goosegodz's Avatar
No worries George, Thanks again for all your help!!!!!
Just have to get the AMP powersteps , Smittybilt light bar with Rigid dually D2's and 20" rigid on and ill be all set....
Well, until my pocketbook recovers and I order the LT airbags and onboard air system with train horns..
