sway bar end links bushings worn - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-26-2013, 03:52 PM Thread Starter
Hello All,
Have some questions regarding the sway bar end link bushings, am i better off replacing the complete sway bar end link or just replacing the bushing and re-using the OE sway bar link?
Also is there a certain brand I should use. When i googled sway bar end links i noticed that MOOG, XRF, MEVOTECH kept popping up.
Thanks
KR
2002 Ex 7.3 4x4 130k miles
4 inch turboback W/5" Tip
AFE intake
6pos chip
Viper remote starter
285/75/16 Nitto Terra Grapplers
My to do list
Gauges
BTS tranny
Train horn
2.5 inch lift
305/70/18
kingranch550 is offline
post #2 of 7 Old 03-29-2013, 09:15 AM
It depends on the type of bushings that you have. There's the standard rubber bushing and the "spherical" bushing. From the research that I have done on my truck, if it's the spherical bushing, then the entire link must be replaced
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #3 of 7 Old 03-29-2013, 09:32 AM Thread Starter
Is there a way to tell which of the two types mentioned I would have? Also does anyone know where is the best place to buy them?
Thanks
KR
AFE intake
6pos chip
My to do list
Gauges
BTS tranny
Train horn
2.5 inch lift
305/70/18
post #4 of 7 Old 03-29-2013, 09:57 AM
Check this out, it may help, it certainly gave me some ideas.
Front Sway Bar Bushing Replacement (with pics) - Ford Truck Enthusiasts Forums
Karls03 is offline
post #5 of 7 Old 03-29-2013, 03:47 PM Thread Starter
Great link. Thanks
AFE intake
6pos chip
My to do list
Gauges
BTS tranny
Train horn
2.5 inch lift
305/70/18
post #6 of 7 Old 03-27-2015, 10:13 AM
BioStroker's Avatar
Quoted: 4 Post(s)
I know this thread is a little old, but I'm looking to replace my Front Sway Bar Links, and I'm wondering if I have the correct part number. I'm looking at Moog K80274, K80273, and K80201 for the sway bar bushing kit. I do have a leveling kit on my truck, so I wasn't sure if I need longer arms for the link kit.
My truck is a 2000 Ford F350 SRW 4x4 with front leveling kit.
Do lifted and leveled trucks need longer Front Sway Bar Links?
2000 F350 Crew Cab Short Bed,
AIS Intake/Zoodad, 203 thermostat, Billet Housing
Vegistroke WVO conversion, AIH Delete, Wicked Wheel, TurboMaster Wastegate controller
Pyro/Boost/Tranny Guages
4" Magnaflow Straight Pipe
DP-Tuner F6 80hp Econo, 80hp Tow, Decel, 100hp Performance, 120hp Race
BioStroker is offline
post #7 of 7 Old 03-28-2015, 04:41 PM
michaelite's Avatar
Quoted: 22 Post(s)
Just replaced mine today using MOOG end links but I have an 08. Not sure they will be the same ones. If it helps, mine is also leveled and used same size as OE. They did not need to be longer.
michaelite is offline
