I thought F350's had a 4" rear block... - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 23 Old 03-24-2013, 07:45 PM Thread Starter
After installing a leveling kit I noticed the rear of my Truck sits alittle lower then the front now. I measured the Rear Spring Blocks and they are 3 1/2". I thought they all were 4". I was hoping for a slight rake. Is there a such thing as 4 1/2" blocks?
2005 F350 KING Ranch 4x4
Thanks,
Ray
rtkjadams is offline
post #2 of 23 Old 03-24-2013, 08:00 PM
F350's are 3.5" rear blocks, u could just stack a 1" on top.
Gb
2006 F350 lariat 4x4, S&b intake, 4" exhaust, 03 turbo, sinister egr cooler, BPD remote oil cooler, BPD FICM, stc and dummys, diablowsport program, 5" lift, 35's, led fog bar, flatbed welding rig. SOLD. Went the darkside, 2014 ram 3500 daully.
gblauf is offline
post #3 of 23 Old 03-24-2013, 09:35 PM
There's a reason why they call it a leveling kit
Not all F350's have the same rear block either. I do not know why people call them 4" blocks if they only measure 3.5". My dually F350 only has 2" blocks but measure around 1-7/8"
Also what kind of leveling kit did you get?
Also I would not stack blocks, but that's just me. I know it will cost more, but you can get a set of PMF blocks
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
post #4 of 23 Old 03-25-2013, 09:07 AM
We have blocks available in 1/2" increments from 1 to 6 inches.
We have 4 1/2" blocks available here:
TGC: 99-12 Ford F250/F350 / 00-05 Excursion 4.5" Steel Fabricated Lift Block Set
Remember, as a forum member you get a 5% discount.
Thanks,
Derek
Supporting Vendor
Now Under New Ownership!
We Pride Ourselves on Customer Service and Customer Satisfaction.
Give us a call at (865) 681-3008
Also #topguncustomz on Instagram!
Top Gun Customz is offline
post #5 of 23 Old 03-25-2013, 10:13 AM
upd103's Avatar
Send a message via Yahoo to upd103 Send a message via Skype™ to upd103
The guy who invented dimensional lumber was hired by Ford to design the blocks.
He figured a 2X4 was only 1.75"X3.5", therefore a 4" block should only be 3.5".
There ya go. Mystery solved.
Jarrod B likes this.
-David-
upd103 is offline
post #6 of 23 Old 03-25-2013, 10:48 AM
cntryboy17's Avatar
Re: I thought F350's had a 4" rear block...
Gb
DO NOT STACK BLOCKS!!
FB: Kyle Durflinger
E99 F350 CCSB 4x4, Auto, All stock for now..., straight piped
1990 f-250 7.3idi 4x4 5 speed
Originally Posted by oldtimer550 View Post
Chevrolet = French word for non-hetero buttsecks.
Originally Posted by 1tonpower View Post
the wait for the coverage articles in DP is like waiting for a girl to put out for the first time....
cntryboy17 is offline
post #7 of 23 Old 03-25-2013, 11:10 AM Thread Starter
Thanks,
Derek
What will I do about the bump stops?
Ray
post #8 of 23 Old 03-25-2013, 11:34 AM
NotStock's Avatar
Depending on your cab/bed configuration you will probably want to go with a 2.5* taper. Our blocks have three different taper options and are available with or without a bumpstop tang. If you have any questions, just let me know!
-Trevor
Ford Fabricated Lift Blocks
Precision Metal Fab
Trevor Hall
(520)465-7971
NotStock is offline
post #9 of 23 Old 03-25-2013, 11:37 AM
NotStock's Avatar
I also just checked stock and I have a pair of 4.5" 2.5* taper blocks with the bumpstop tangs instock...
Precision Metal Fab
Trevor Hall
(520)465-7971
NotStock is offline
post #10 of 23 Old 03-25-2013, 12:20 PM
Hey Trevor,
When do you know if you need a taper? I have 2" flat blocks on my dually but I was thinking of putting a set of your 4" blocks on. I am not sure if I need to go with a flat block or 2.5* taper.
I am not fully set on what I want to do yet, just trying to do my homework first. Thanks
INFRNL is offline
